20 Most Recent
Blaupunkt Santa Cruz MP36 CD Player Questions & Answers
How to remove a blaupunkt santa cruz mp36
I'm afraid its a little bit late for corsamad11 but I've just spent hours finding that too much messing about taking a Blaupunkt Santa Crux MP36 in and out of your dashboard will almost render this great quality radio almost useless. Not being securely fixed in the dasboard.
The radio is held inside the mounting bracket by a metal strip each side which are supposed to spring closed to secure the unit. When the two keys are inserted each side of the radio they are supposed to push out these metal strips and at the same time hook onto each side of the radio behind two little lugs. This may work a few times but thats about all. The metal strips don't spring closed and the removing keys don't hook on the unit to pull it out.
Fiddle about with the keys inserted in each slot and at the same time try to push the unit further inside the dash. When this is achieved the mounting bracket lugs can be straightened out and the bracket can be removed with a narrow screwdriver as installed.
Just a very poor and flimsy design on a much loved radio.
Hi thereI have a holden barina 2004 with a Blaupunkt 2020 radio.
Radio codes are unique to each vehicle and are typically provided by the vehicle manufacturer or the radio manufacturer. To obtain the code for your specific radio, you will need to contact a Holden dealership or a Blaupunkt authorized service center. They will be able to assist you in retrieving the correct radio code.
You may need to provide proof of ownership and the serial number of the radio (which you've already provided as BP248554092649 No 92 094 577). Once you have the correct code, follow the instructions in your owner's manual to enter it and unlock your radio.
Suzuki Ignis radio code
Hi I have suzuki ignis too and I have problem with radio code too...but I am from slovakia and my english is so amynous...and I dont understant this web side (
www.ukbookshelf.co.uk) its free ?
39101-86G1
ID: 39101-86G1.......like gedwards80 on the top :)
