20 Most Recent Frigidaire GLTF2940WH Questions & Answers
it pretty much has to be coming down the front, underneath the door. If your rubber boot is really dirty or has a lot of hair on it this will happen.
Frigidaire... | Answered on Nov 08, 2010
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!
Frigidaire... | Answered on Sep 16, 2010
You can call or email the manufacture to find out.
Frigidaire... | Answered on May 27, 2008
No, a sensor proble
Frigidaire oven code f10
A faulty RTD sensor probe is one of the causes for an F10 code or overheating oven. The sensor probe is supposed to detect the exact temperature in the Frigidaire electric range cavity and relay it to the oven's main control so it knows when to shut off the heating elements.
What Does the F10 Code Mean on a Frigidaire Electric Range ...
Frigidaire... | Answered on Aug 19, 2020
Loose connector on the main user interface circuit board.
Frigidaire Affinity Front Load Washing Machine Error Fault ...
removeandreplace.com > Home DIY Repair > Washing Machine Repair
Oct 28, 2014 - The E91 error code is signaling an issue with the User Interface board that has all of the indicator lights on it. A connector has likely become ...
My Affinity washer stopped working, E91, after I installed the ...
www.justanswer.com > ... > Front Load Washer Problems
Jul 29, 2012 - The E91 error code is signaling an issue with the User Interface board that has all of the indicator ... FAFS4073NR Frigidaire Affinity 3.8 Cu.
Videos
https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk01rsvtUZWbee64zkjPN4pSaqvEG4w%3A1591718377476&ei=6bHfXuPcHKDDytMP0rKUgAY&q=frigidaire+washer+error+code+e91
Frigidaire... | Answered on Jun 09, 2020
The E11 error code indicates a problem with the gas sensor DE32-60011A and or the wire harness DE39-40678D. Unfortunately the manufacturer has discontinued the sensor. You may want to try contacting local parts dealers, one of them might still have it in stock. Enter your part number in a search engine, a smaller company might have it or try eBay, Amazon or similar sites . Search by using the manufacturers part number. Try a used appliance store, sometimes they have the same model or a usable part for your machine.
Frigidaire... | Answered on May 07, 2020
Sorry to read about your problem.
Sorry no reset switch.Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Frigidaire... | Answered on Apr 27, 2020
Recheck the outlets and if they are on the same circuit as the dryer then you could have a problem with the wiring . My feeling if the living room outlets were changed there should be no connection between the living room and utility room. One way of telling is to get an extension cord and hook it to your dryer and to different outlets in the house that you know is working.f there is power on the living room receptacles then plug the dryer extension into them.
Frigidaire... | Answered on Feb 11, 2020
Frigidaire GLTF2940WH Logo
Popular Tags
5 questions posted
Top Frigidaire Washing Machines Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Poppa Maddo
Poppa Maddo
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
frigidaire gltf2940fs front load washer
  • Washing Machines
