20 Most Recent Sony MUTEKI HTDDW1600 Theater System Questions & Answers
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown
Sony MUTEKI... | Answered on Nov 21, 2017
Sony Muteki with USB Fail message or turning on and off is generally related to a faulty mains input relay. Search for it in the schematic and replace with a stronger part. Sony uses a very weak relay to connect the mains after power button is pressed. It doesn't last too much.
Sony MUTEKI... | Answered on Jun 04, 2015
i have the same problem ):
Sony MUTEKI... | Answered on Apr 16, 2014
Please check all your audio settings. Are you trying to connect the audio output on your Play Station to your Blu Ray, or are you trying to connect your PS to an AV Receiver? You may contact me through my website ay AUDIOSERVICECLINIC.COM.
Thank you, Dave
Sony MUTEKI... | Answered on Apr 01, 2014
It can be many different issues; too many to go into on this website. It is most likely DC Offset, meaning a damaged amplifier. Please contact me directly at AUDIOSERVICECLINIC.COM for more information. You may contact me directly through the website.
Thank you,
Dave
Check your owner's manual for a Factory Reset, or Return to Default. Try that first. If it still doesn't work, try disconnecting the sub completely, and see it that resolves the issue.
Sony MUTEKI... | Answered on Feb 10, 2014
My subwoofer recently burnt out because I had it plugged into a different amplifier.. I wouldn't recommend it. Sony has released the sub to suit that system.. Do keep in mind that I did have bass boost on with the sub up full (Which didn't matter when I had it connected to the Sony amplifier..).
Proceed with caution.. I would recommend turning the sub down and using the sub volume control on the amplifiers settings to change the volume.. Just do not run it at a pace where it looks like it is stressing.. When I say stressing I mean, looking like it is going to jump out of the enclosure..
-Dubkingz
Sony MUTEKI... | Answered on May 07, 2013
There is a short in the amp that needs to be repaired before the unit will power on normally.
Sony MUTEKI... | Answered on Mar 19, 2013
You can turn off the 7.2 channel surround sound system if you only want to listen to audio on the TV channels, you may need to increase the volume levels on the TV.
Use the 7.2 channel surround sound when you want surround sound when playing DVD movies.
Sony MUTEKI... | Answered on Jan 10, 2013
Sony MUTEKI HTDDW1600 Theater System Logo
64 questions posted
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
wife says muteki 7 2 chanel not need
  • Audio Players & Recorders
