20 Most Recent Onkyo TX-SR605 Home Theater Receiver 7.1 Channels Questions & Answers
Just freq. error, by lowering the input
freq. can fix the problem.
Onkyo TX-SR605... | Answered on Mar 02, 2020
If the settings are correct, then it is just like the 605 I had, its broken. Get one made by someone else if the warranty has expired on it. I suggest Pioneer.
Onkyo TX-SR605... | Answered on Jan 27, 2015
Try pressing and holding DVD button and pressing power button. It should reset it to factory settings.
Onkyo TX-SR605... | Answered on Nov 26, 2012
Mike, I would agree. ANY device that either IS or emulates any hi-fi A/V device should work just fine assuming it doesn't deviate from the hardware standards of the 'real' hardware. Your Media PC is just another digital source as far as the receiver knows. Manuals don't mention everything because it is assumed that we know we can substitute compatible devices among the various in/outputs.
However, my own practice is to run every signal directly to the best device that enhances or uses it. NO VIDEO to my AVR (it goes directly to my monitor); NO HIGH-END AUDIO to the TV (it goes directly to my receiver). NO EXCESSIVE CABLES. NO PROBLEMS WITH UNNECESSARY CONNECTIONS. NO CORRUPTION OF ANY THE SIGNAL.
My PC's soundcard feeds both digital and analog audio inputs on my receiver so I have the flexibility of manipulating it in the analog domain for re-recording or just listening.
Onkyo TX-SR605... | Answered on Nov 10, 2011
Use an HDMI switcher like this. Then you can select any of the three inputs and run it to the receiver. Simply leave the receiver on that input and use the switcher for source selection.
Onkyo TX-SR605... | Answered on May 28, 2011
Not sure what unable to connect means..but I will assume you have the correct cable.
First make sure you have plugged the from the HDMI cable from the DVD play into the IN 1 HDMI port on the back of your Onkyo
On the Receiver
Enter the Setup mode
Select INPUT OUTPUT ASSIGN
Next make sure the HDMI monitor out is set to YES on the Receiver
Monitor out
HDMI Monitor - YES
Next you need to assign the HDMI INPUT to DVD
HDMI INPUT
DVD - IN1
CBL/SAT - IN2
This may be your issue.
Next step would be to verify your television input settings.
Nice receiver!
Best of luck!
Onkyo TX-SR605... | Answered on Apr 20, 2011
Tip
Onkyo TX-SR605 Manual Download
Download Onkyo TX-SR605 Manual
Models: RC-682M / TX-SR605 / TX-SA605 / TX-SA8560
Have you misplaced your Onkyo TX-SR605 Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Users Guide?
Follow this link to download a pdf version of the operations manual.
I hope that helps.
________________________________________________
RC-682M Remote Code List & Programming Guide Here.
on Apr 20, 2010 | Onkyo TX-SR605 Home Theater...
Tip
Onkyo TX-SR605 Remote Codes
Download Onkyo TX-SR605 Remote Codes
4 Digit Onkyo Remote Codes
Have you misplaced your Onkyo TX-SR605 Remote code list / Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo TX-SR605 Universal Remote Code List Users Guide?
I hope that helps.
Download Onkyo TX-SR605 Users Manual Here.
Tip
Onkyo RC-682M Remote Codes
Download Onkyo RC-682M Remote Codes
Have you misplaced your Onkyo RC-682M Remote Owners Manual?
Would you like a digital, searchable, pdf version of the Onkyo RC-682M Remote Users Guide?
I hope that helps.
no mention of speaker wire size or length but the internal thermal shut down circuit is very sensitive, if even one channel goes into thermal protection it shuts the unit down, quick fix is cans of compressed air for computers and clean the inside of dust the factory set thermal cut off is 39.1 to 43 degrees celcius with an impedence check of not less than 4 ohms, your fan trick sounds like the right start the volume setting is not absolute there fore it may be your units actual voltage, amperage wattage conversion output is at its limit, heat is electronic death take great care to avoid heat, large amps have massive heat sinks your sony is not one of them
Onkyo TX-SR605... | Answered on Sep 10, 2009
Sir! If you recently have bought this machine and it is new, don't cheat yourself out of your warranty. Go put on the lap of the people who sold it to you..............
My name is Constantin (arzconst is my internal nickname for Fixya.com)
Onkyo TX-SR605... | Answered on Jun 16, 2009
Request the service manual directly from Onkyo.
Onkyo Audio... | Answered 2 days ago
Probable power supply failure
Onkyo Audio... | Answered on Nov 11, 2020
You probably blew the output stage and it is operating in protect mode until you repair it.
Onkyo TX-SR605 Home Theater Receiver 7.1 Channels Logo
Popular Tags
20 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
hook up netflix internet
  • Audio Players & Recorders
