20 Most Recent Frigidaire Gallery Supreme Series GSTF1670DS 3.1 cu.ft. Front Load Washer Questions & Answers
Frigidaire gallery series front load washer
turn down the water pressure on the water line to the washer if the water pressure is to high it will splash out of the filler. there should be a vale on the main water line to the washer.
5/19/2017 2:53:31 AM • Frigidaire... • Answered on May 19, 2017
My dryer starts but drum doesn't spin. what is this?
Unplug it and locate the access panel or remove the top lid. Look inside and see if the drive belt is busted. If it is get the machine details off the sticker on the back and call an appliance spares shop or go online. Any good DIY person can change it.
2/17/2016 9:38:00 PM • Frigidaire... • Answered on Feb 17, 2016
Drum drive motor does not spin
No spin, try these: Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. The lid switch assembly can fail either mechanically or electrically. Check the clutch, brake assembly and transmission, one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand. Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either) Next check for a loose, worn or broken belt if belt driven. On some front load models u may need to check the STATOR assembly. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
4/1/2015 12:35:17 AM • Frigidaire... • Answered on Apr 01, 2015
Door latch not working therefore cannot use.
Verlin, this is JK. I understand that you are having concerns with the door latch. Before considering contacting a service provider, I would recommend resetting the appliance by turning off the power to the washer for about five minutes. After the five minutes return power to the appliance, this should allow the washer to return to working condition. You may also want to check to ensure the door is aligned. If all of these suggestions pan out and the problem still persists, think about what may have happened prior to this occurrence. For instance, did you notice any error codes, odors, or other strange functions prior to this issue? If you are still having these issues and can think of anything in particular, please feel free to reconnect. Hope this helps!
4/15/2014 6:06:26 PM • Frigidaire... • Answered on Apr 15, 2014
My frigidaire gallery washer will not spin all other functions are ok
Is the motor buzzing or is it buzzing at the console?
11/4/2012 11:09:49 PM • Frigidaire... • Answered on Nov 04, 2012
Wash cycle does not complete itself,spin leaves
The water is drained at the end of each cycle by the drain motor.
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
3/8/2011 8:47:08 PM • Frigidaire... • Answered on Mar 08, 2011
Water will not drain and washer will not spin
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
9/1/2010 3:02:34 AM • Frigidaire... • Answered on Sep 01, 2010
Sounds like a bangin when its in spin cycle need help please
If this is a front loading washer, the spider arm is broken at the back of the drum. Big bucks to repair this. You might as well buy a new machine.
5/25/2009 3:41:15 AM • Frigidaire... • Answered on May 25, 2009
Electronic controls
You need to replace the control assembly, you find replacement part and schematics here.
You will need to inser your model number.
See here if you need help finding the model number on your appliance.
10/11/2008 11:44:27 AM • Frigidaire... • Answered on Oct 11, 2008
Frigidaire FFLE3911QW0 combo washer/dryer is starting and locking then it won't do anything else. Please someone help!?!
There are a couple of videos and text based articles in the link, plus disassembly. I would check connection on the control board connections and those on the lid lock. The lock has to be functioning properly to operate. https://www.google.com/search?q=Frigidaire+FFLE3911QW0+combo+washer%2Fdryer+is+starting+and+locking ..
9/20/2021 6:22:09 PM • Frigidaire... • Answered on Sep 20, 2021
How do I repair a washing machine?
Common solutions for: Frigidaire Washer won't spin or agitate. Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it. If the lid switch assembly fails, the washer will not spin.
9/10/2021 12:51:58 AM • Frigidaire... • Answered on Sep 10, 2021
Have a frigidaire dish washer not draining properly.
Check and clean/clear bottom drain screen if have one pump operating properly and main drain line for clogging
9/3/2021 3:51:09 PM • Frigidaire... • Answered on Sep 03, 2021
How to fix Frigidaire affinity front load washer will not complete the spin cycle
sounds like the transmission needs replaced
8/21/2021 9:40:18 PM • Frigidaire... • Answered on Aug 21, 2021
Errant earring
assuming this has long since been dealt with, but if its not in the rubber gasket at the front of the machine, take off the bottom panel at the front, there is a small pump there that drains the unit. It may be trapped in there. You can use pliers or vice grips to remove the couplers holding the hoses on and a screwdriver to remove it.
8/16/2021 8:03:34 AM • Frigidaire... • Answered on Aug 16, 2021
Frigidaire Gallery front loading washing machine won't spin.
Replace the failed bearing at the rear.
8/6/2021 4:49:20 AM • Frigidaire... • Answered on Aug 06, 2021
I can't get the "loc" display to reset from my Frigidaire gallery dishwasher
Try pressing and holding the Delay Start button for ~3 seconds. The 'loc' indicator should go out. If you hold the button for too long, then the lock could toggle back on. If the problem persists, you may have an issue with the keypad on the dishwasher. I hope this helps. Please add a comment with the model number of the dishwasher if the control panel lock does not disengage. Cindy Wells
7/9/2021 9:52:23 PM • Frigidaire... • Answered on Jul 09, 2021
Washing Machines Logo
17 questions posted
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Michael Thomas
Michael Thomas
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Washing Machines
Most Popular Question
dryer starts but drum doesnt spin
  • Washing Machines
