click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or
if you can see your usb but its not workingports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luckyou might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap hope this helps
3 questions posted
3,739 Questions
247 Questions
43 Questions
42 Questions
26 Questions
