20 Most Recent Dane-Elec DaneElec 4GB USB Drive Blue Hard Drive Questions & Answers
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Dane-Elec... | Answered on Feb 11, 2012
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htmwww.CardRecovery.com
Dane-Elec... | Answered on Apr 20, 2011
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
ports(com&lpt)right click update driver
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
don
Dane-Elec... | Answered on Mar 03, 2011
Are you based in the UK? if so SaveMyUSB.com could help you. Good luck
Dane-Elec... | Answered on Jan 10, 2011
16.99
Dane-Elec... | Answered on Apr 03, 2010
As well as any other device, a memory card can suffer from various influences and so it may break down for a number of reasons. In this article, we'll consider possible causes of damage to memory cards and give a couple of hints at recovering their data.
https://hetmanrecovery.com/recovery_news/repair-sd-and-restore-data-from-a-damaged-or-not-working-memory-card.htm
Dane-Elec... | Answered on Jan 14, 2019
When a Universal Serial Bus [USB] drive doesn't show up in your computer, it can be an urgent problem, especially when you need to access files or data stored on the drive.
It is not easy to troubleshoot this issue, compared to other computer problems, because there are a few probable causes for the problem.
On a positive note, USB problems generally require one simple step to resolve.Name Conflicts
This problem generally occurs on computers with an exceptional number of attached drives, whether they are networked, or hard-wired.
Computers with multi-format card readers can have this issue.
USB drives don't always find an available drive name that is compatible with their naming conventions.
For example, if the USB drive is named "G:," and your computer has a networked drive "G:," or additional hard or optical drives named "G:," your USB drive will not show up.
This problem can be resolved by remapping a drive to a different name; this can either be a temporary name change, or permanent.
One thing to keep in mind, is that drive remapping is not something that a computer novice should attempt.
Consult a technician for help with remapping/renaming a drive.
Software Conflicts
With newer computers, it is much more unlikely, but there could be a chance that your USB drivers are not installed.
Checking your USB drivers is a simple as right-clicking "My Computer," and selecting "Properties."
From the Properties menu, select the "Hardware" tab, and click the "Device Manager" button.
A list of your computer's hardware will open, and you will find "Universal Serial Bus" on the list. If you see a red "X" or yellow exclamation point, your drivers are not installed.
Drivers vary by computer; if you cannot find the driver disk that came with your computer, you will need to go to the website of your computer's manufacturer to locate and download the driver.
If you are not comfortable downloading and installing software, contact a computer technician.
Drive Malfunction USB drives are more durable than floppy disks and their predecessors, but they are not indestructible.
If your computer does not detect your drive and it has before, test the drive in other computers.
If the drive does not show up in several computers, there's a good chance that it has gone bad. Repeated rough handling of a USB drive can damage the memory chip on the drive.
Removing the drive without "stopping" it can corrupt the drive, as well.
USB Port Malfunction
Most USB drives have a small led that will light up when the drive is inserted into the USB port.
If the LED does not light, it could indicate a problem with the drive, but there could also be a problem with the computer's USB ports.
If the drive does not light up, and is not detected, plug it into another computer.
If the drive is detected by the other computer, there is a problem with the original computer's USB ports.
Follow the steps in the Software Problems section of this article to check if your USB drivers are installed. If they are, you may need to contact a technician to check your USB port connections.
The USB ports on the computer may have been connected when the computer was manufactured or recently serviced.
If you are not comfortable working on your computer, contact a technician.
Failure to take certain precautions could result in damage to your computer's motherboard.
Expert Insight
Whether your drive is new or you've had it for a while, do not be over-reliant on its durability. Keep at least one additional copy of your data in another location to avoid catastrophic data loss.
USB drives are not indestructible, and it is not always possible to recover data from them, even under favorable circumstances.
Dane-Elec... | Answered on Aug 08, 2013
Step 1:
Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it. Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Dane-Elec... | Answered on Feb 03, 2013
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
if you can see your usb but its not working
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.
Then restart computer then check.
Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luck
you might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap
hope this helps
Dane-Elec... | Answered on May 17, 2012
What brand of flash drive is it? Try doing a Google search with the keybords "4Gb flash drive [brand] driver" and you should be able to find a download.
Dane-Elec... | Answered on Apr 10, 2011
Did the hard drive come in the enclosure? (Is the hard drive supported by the extrenal enclosure) Does it work when plugged into another computer and have you tried using another cable?
Did it come in the enclosure? Try another cable
Did it work when plugged into another computer?
Yes - Windows Drivers
No - Try another enclosure or cable
Did it work with another cable?
Yes - Problem Solved
No - Try another enclosure with the new cable
try whichever of these and see if it helps. please respond here with what happens wether it works or not.
Another option by the way is to check what happens when you take the hard drive out of the enclosure and install it inside the computer as an internal Hard Drive. If that works then it isn't the hard drive atleast. I will away to see what happens.
Dane-Elec... | Answered on Feb 04, 2011
this post contains no information
Computers &... | Answered 5 hours ago
google it
SEO stands for search engine optimization, which is a digital marketing strategy that focuses on your website's presence in search results on search engines like Google. When you understand how SEO works, you can use different tactics to increase your visibility (or how high you rank) in search results.
a fragment of a sentence is a
Maybe you don't have it set up to be able to send money.
Computers &... | Answered 6 hours ago
Dane-Elec DaneElec 4GB USB Drive Blue Hard Drive Logo
9 questions posted
Top Dane-Elec Computers & Internet Experts
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
Hetman Software
Hetman Software
Are you a Dane-Elec Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Dane-Elec Computers & Internet
Most Popular Question
think doesn 39 t work
  • Computers & Internet
