20 Most Recent Samsung SpinPoint T HD501LJ 500 GB SATA Hard Drive Questions & Answers
I'm assuming you are on windows. Right click on My Computer and select Manage. Select the Disk Management option on the left. Right click on the partitions you are missing a drive letter for and then select Change Drive Letter and Paths. That should let you choose the drive letter.
Samsung... • Answered on Aug 02, 2014
Well I know what that means. You better back up everything and go buy a new hard drive. That is a sign it is going to fail
Samsung... • Answered on Sep 12, 2011
You need to prepare the drive for Windows. This unfortunately usually means reformatting. You should be able to tell it to reformat and prepare the drive from the disk management console if you right click on the disc.
Samsung... • Answered on Apr 07, 2011
Your hard drive is dying. The best thing to do would be to immediately back up any files you want to keep onto an external hard drive. Replace the hard drive and restore your files. I'm sorry for the bad news but I hope this helps.
Samsung... • Answered on Mar 02, 2011
This is known as the click of death. You can see a full explanation and how to solve it by checking out this YouTube vid.
Samsung... • Answered on Feb 14, 2011
Hi, Thanks for using fixya.
Replacement is easiest and cheaper It is a problem with your device not the drivers or software. You could take it in and see if it could be repaired. If it is under warranty opening the disk case will void the warranty.
Hope this helps
Terry
Samsung... • Answered on Feb 13, 2011
Hi!
That can be done from BIOS setings. First check that both the disks have been detected by the BIOS.
Usually, the hard disk at sata1 (1st sata connector on board is for master drive.
Secondly, look for the bootup option and choose maxtor as primary drive (to boot from it)
Hope this helps!. let me know about *********** board details also, if further any assistance is needed.
CreativeTECH
Samsung... • Answered on Nov 10, 2010
Connect it to a different computer. If it still is not detected, then there is a hardware problem. Exercise the warranty to get it repaired/replaced.
Samsung... • Answered on Nov 02, 2010
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Samsung... • Answered on Sep 11, 2010
Tried a differant SATA power inout into it? Is it making a clicking sound?
Samsung... • Answered on Jul 29, 2009
To download songs just go to the website from where u want to download song then there should be download button around a song to download.Just click on it and your download starts.
thanx
Samsung... • Answered on Mar 31, 2021
1 Turn on the computer, then press the F4 key several times before the Samsung logo appears to open Samsung Recovery. 2 Click Computer Factory Reset 3 Click the Start Factory Reset button. 4 When the Start reset confirmation screen appears, click OK. 5 Your PC is reset. (Please note: resetting may take some time, depending on your PC.) 6 When a message appears saying reset is complete, click the OK button. 7 The PC will restart. 8 Finish setting up your PC according to the on-screen instructions. 9 After rebooting, check that your PC has been reset correctly.
Samsung... • Answered on Mar 27, 2021
Do you have a recovery CD or DVD that came with the unit? If so, try booting up from the cd and perhaps it will let you run a repair? Of if you can get into the BIOS of the unit, and that may be hard if your keyboard doesn't work, see if there's an option to activate the keyboard before bootup. Another idea is plug an external USB keyboard in and see if that works after a reboot.
Samsung... • Answered on Mar 08, 2021
check junk folder , check spam folder smart tv uses what system ? google android ? download app to tv from playstore if android system ??
Samsung... • Answered on Feb 12, 2021
Samsung SpinPoint T HD501LJ 500 GB SATA Hard Drive Logo
22 questions posted
Top Samsung Computers & Internet Experts
Jean Thiebaux
Jax Planet
Jax Planet
aliasger yq
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Spinpoint Samsung
  • Spinpoint Samsung
Most Popular Question
get clicking sound
  • Computers & Internet
