20 Most Recent
Frigidaire GLWS1339CS Top Load Washer Questions & Answers
LG tromm washer stuck in rinse cycle
- I had the same issue of being stuck in rinse and timer stuck at 20 min. Mine was a water flow problem, at the back of the washer where you hook up the water there is a small in line screen to stop debris from water supply. I removed them, they were clogged, cleaned them up, works great!!!
Why does my washing machine does not drain the water inspite of replacing with a new drain pump
Good Morning Friend,
I understand that your Frigidaire washer, model# GLWS1339CS, will not drain the water even if you program it to just drain. I also see that you just replaced the drain pump in your appliance. I suggest checking the drain hose to make sure it is not kinked or clogged. I would also check your home's drain system to make sure that it is not clogged either. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
How do i remove cabinet from my washing machine?
It is simple front panel is usually hold in place with some clips and screws and some times some notches in the bottom
Look for screws in the bottom and panel is removable by couple of screws in the bottom and couple of clips on the top
My washing machine gets stuck after rinse cycle
Before spending any money calling a repairman or changing parts, check the drain hose. If it is too deep down into the drain pipe then pull it back so that only about 6 to 10 inches is down the pipe. If it is too far down then it creates a vacuum which drains the water as it is trying to fill for the final rinse.
Smells like rubber burning and
probably the belt . Make sure the tub is turning freely . If not check for nail in one of the holes or an article of clothes jammed between tubs. If it turns freely just change the belt
Washing manchine water overflowing over the top
where the hoses go into the machines you will notice those valves are controled by solnoid switch thats what starts and stops water flow as you turn selector knob you should hear them click if that turn off water supply remove hoses from back of machine check if filter screen is in place and that there is no trash keeping valve open p.s switch from hot and cold to see which one needs to be replaced or repaired
Don't want to spin motor running, push by hand
So, the motor runs all the time but the belt is skidding until the drum is pushed? Apart from the belt tension perhaps being too low, the 'click' suggests that the bearings on the drum are shot, making them lock up in certain positions at rest. ,
My washer emties as quick as it runs in and wont
If your washer is emptying like that it is because your drain hose is too low. The water is siphoning out of it.
Raise the standpipe up and get the hose up higher and you will be okay.
Now this is assuming that your pump is not running which you didnot state. If your pump is running and pumping the water out then you have problems with the timer switches and need a new timer.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
When starting the wash or rinse cycle, the washer
Assuming the motor isn’t running during fill the water
is siphoning out and can be
caused by a few things.
- The drainpipe to your house may be too low and you either
need to extend the pipe up above the top of the
tub or run the drain hose from your washer up
high.
- Someone may have taped the drain hose from the washer to the drainpipe to
your house to stop the water from
backing up. To fix this either clean out the
drainpipe to your house and remove the tape or install a siphon break.
- If the drain hose from your washer is pushed down the
drainpipe too far, this will also cause the same problem. To fix it just
pull it out to within
about 6 inches of the
end of the drainpipe.
10/11/2009 10:12:05 PM •
Frigidaire...
Answered
on Oct 11, 2009
