20 Most Recent
Cavalry Storage Cavalry CADA001SA2 External 7200RPM 1TB USB 2.0 / eSATA Hard Drive Questions & Answers
Cavalry hard drive gets error message
click start control panel administrative tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if it's a program file you might uninstall the program restart your computer then reinstall some of these files/software
hope this helps
Constant beeping from Cavalry external HD
Can't say exactly what it means technically speaking, but my experience with such a problem is that the drive is 'dead'. Of course trying it on another computer would be constructive.
My black calvary external hard drive won't turn on.
Would be great if the next time you also place the model number, because Cavalry makes dozens of different drives.
When the bleu light does not go on, you have to assume the drive is not getting power.
If the drive has only one cable, (small drives like 2,5 inch most of the time only have one cable) it could be the USB cable is defect and can't give through the 5 Volt coming from the computer USB connector. It also could be the 5 Volt supposed to be in the computer has gone.
If you have to connect an external power supply, with a small cable to the drive, I would check the power supply. A 5 Volt 2 A supply, with the round plug can't be that expensive.
If both don't work, it also could be inside the housing of the drive is something defect.
If you need to have the data on the drive, you always could but an universal USB connection for hard drives. I have one for IDE and E-SATA, in the box came a set power cables and a power supply, but that one was almost 50 dollar. There are cheaper ones on the net.
Be aware drives don't live forever and make sure you always have at least two backups. (that is more than one origin; and one back up)
Error message says I don't
It sounds like your network administrator has locked your ability to write to certain folders. If this is a home hard drive, the only way to fix this would be to completely reinstall windows. If it's a work computer, you need to talk to your IT Department.
-Alex
CAUO37500 Lite's on but nobody
im not sure how bad your hard drive is but if it works on another computer
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps also
you could run the chkdsk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input may damage your computer
then defragment your hard drive
also you might download and use this registry cleaner it is totally free to use
http://download.cnet.com/ccleaner/
Transfer between 2 External Drives
the best program for this file transfer is Director Opus 9 this can transfer 100gig in under 1hr as with windows transfer takes 6hrs.
As I do alot of video capture and my filse range from 400mb to 4gig in size and having to transfer 700 gig about would take forever and with this program quick and easy you also can transfer over lan or wirless net.
happy transfering
Sir i an having a
That is because your screen resolution in very high..means out of frequency of the monitor. Restart your pc and press
F8 to get
safe mode options.once you get safe mode window select
Enable VGA mode using up or down arrow keys and press enter. Now you will get your desktop.
Now right click on an empty space in desktop and go to
properties and go to
settings tab. In
screen resolution tab change the resolution to
1024 by 768. Then press Apply and OK. Now you can restart and see your computer works fine.
Drivers window struggles going up
They often do. Spray the channels with a clear silicone spray like Jigaloo. The Scotty Kilmer YouTube channel had a product that he said was great. He has thousands of videos but you can use the search feature on his site.
How can i register for efiling
To register for e-filing, follow these steps:
- Go to the e-filing portal of the Income Tax Department of India - https://www.incometaxindiaefiling.gov.in/
- Click on the "Register Yourself" button on the right-hand side of the page.
- Select your user type as "Individual/HUF" or "Other than Individual/HUF" depending on your category.
- Fill in your basic details such as PAN, name, date of birth, and contact information.
- Create a user ID and password, and select a security question and answer.
- Enter the captcha code and click on "Submit."
- You will receive an OTP (one-time password) on your registered mobile number and email address.
- Enter the OTP in the relevant fields and click on "Submit."
- Your e-filing account will be created, and you can start using the portal to file your income tax returns, check the status of your returns, and perform other tax-related activities.
What are a few samples of AI art?
Artificial intelligence has fundamentally changed how we approach every aspect of life, including healthcare and transportation.
AI art is quickly gaining favour among artists and lovers alike, whether creating brand-new works of art or reinventing time-honored masterpieces. We'll look at some breathtaking examples of how artificial intelligence is altering the creative environment and erasing the distinction between man and machine in this blog article.
Best AI art examples
There are many instances of AI art, but these stand out:
1. In October 2018, the French AI artist collective Obvious's painting "Portrait of Edmond de Belamy" became the first AI-produced piece of art to sell at a significant auction, fetching $432,500 at Christie's.
2. Using LED lights that change color and patterns in response to information from NASA satellites, American artist and engineer Dan Goods makes sculptures that appear "alive." His objective is to "increase awareness of the invisible forces that shape our lives."
3. Using machine learning techniques, Canadian artist Kyle McDonald creates visuals and movies that examine how people and technology interact. He employed a neural network to construct a "portrait" of himself made up of hundreds of various facial photos for one of his projects.
4. Taki Hawaii, a Japanese artist, creates ethereal landscapes consisting of countless small dots that are created by AI software looking at satellite data of the Earth's surface.
5. Old Master paintings serve as inspiration for the generative portraits created by Berlin-based artists Mario Klingemann and Christopher Burch using AI. According to Klingemann, he wants to "investigate what creativity is and push the frontiers of what is deemed art" using AI.
A fascinating new example of how technology is being used to produce exquisite works of art is AI art. We can now explore other approaches to creating artwork outside of the conventional techniques in a world where machines can learn how to be creative. These examples, which range from digital abstracts to generative music to neural portraits, demonstrate that AI art has its own distinctive aesthetic and creative potential. This offers up a wide range of possibilities for what else we might see from AI-generated artwork in the future when more developments in artificial intelligence are anticipated.
Hi,I will like to have
Website perform several functions. For example, website provide recognition of business establishments where amongs several data that is provided on site are resources contributing towards establishment operations. Websites may provide resources referencing where for example microsoft device sites provide technical support requirements. Alternatively, websites may have live features where for example, exchange of resources are achievable. Several websites perform various functionalities amongs which assignement resources are contributed towards. For example, school website provide shared resources also possible are assignement resources exploration features. However, websites could be designed to suit specifications explained briefly. If i was asked to design a website to help answer assignments, the following requirement would achieve the process.
First, The course subject would be required to determine assistance type. For example, math classes require calculator websites either as resource formular pages or formular establisment sites. if i was required to design a math class website, the formale sheet would be required to be key coded. Asking a computer programmer to create a web site would require the following lists.
1. The type of website, an example of which is assignment answering resources center.
2. Second, the programmer requires examples of what the website would perform to the requestor. For example, a simple assigments website in maths would have a separate page for calculator functionalities. Alternatively, maths websites may require from the requestor the trype of questions of assigments as module of construction. For example, i want a webpage to calculate by adding numbers. Programmers should be provided with 1+1 =2 where 1+2=3 as programmers visual guide to designing and coding the website. keep in mind that the type of request from the programmer would determine what would be produced.
