20 Most Recent Cavalry Storage Cavalry CADB001U32 1TB 7200RPM USB 2.0 3.5-Inch External Hard Disk Drive 500 GB Hard Drive Questions & Answers
My Cavalry 1TB USB 2.0
Hey Jeff, Sounds like this is something with info you need to keep..Keeping/securing/BACKING UP your data is your priority!! Personally, I would find a QUALITY (ASK a lot of questions.. can they guarantee their work,,- and NOT LOSE your data..!!) .. skip the geek squad - .. computer repair shop..(or some 10 year old).. I would first see if they could copy this drive to another drive (solid state) so you will not lose your data... we are at 4.0 with USB now... 2.0 is becoming the "floppy" of today..I have 3.0 drives and feel left out.. again.. securing/copying/backing up your data is paramount.. Good luck,,,
9/8/2017 8:45:23 PM • Cavalry Storage... • Answered on Sep 08, 2017
Hard Disk won't connect to my computer
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
9/27/2010 6:20:57 PM • Cavalry Storage... • Answered on Sep 27, 2010
Computer stopped recogn drive after install utility progrm
you will probaly have to buy some expensive software to get your data back. or just reformat.
11/29/2009 11:56:07 AM • Cavalry Storage... • Answered on Nov 29, 2009
Calvary 1TB USB 2Bay external hard drive problem
The problem could be the enclosure, not the drive.
I would take the drive out of the Calvary enclosure and install it in another one. Hopefully it will come up and you can access your data.
6/16/2009 3:41:04 AM • Cavalry Storage... • Answered on Jun 16, 2009
Order Details - Aug 17, 2007 17:31 GMT+05:30
used airtel's pcsecure to clean the virus and then automatically the computer recognised the drive
now it is fine
4/19/2009 3:19:38 PM • Cavalry Storage... • Answered on Apr 19, 2009
Computer does not recognize new 1TB ext HD
First I had to reseat one of the drives which had worked loose and become unseated during shipping. Then I had to format the hard drive and finally I had a 1TB external hard drive I could use. The light is still red.
4/5/2009 12:43:39 AM • Cavalry Storage... • Answered on Apr 05, 2009
Need help recovering from a Steel Vine software mistake
well..maybe, and that is a major maybe..sometimes, with really good tools, some of that can be recovered, like when a hard drive crashes. assuming there was no other backup, this is problematic. I recommend you seek a really top flight computer person. This will cost a bundle though.
10/22/2008 10:04:55 PM • Cavalry Storage... • Answered on Oct 22, 2008
Cavalry 3.5 External Storage
Found manufacturer.
9/18/2008 1:44:08 PM • Cavalry Storage... • Answered on Sep 18, 2008
6answers
Cavalry 400GB CACE USB/FW800 7200 RPM 3.5in Mac Formatted
Open a Finder window and type a search word or phrase in the search field in the upper-right corner.
step_2.gif Focus the search by choosing a search location in the location bar.
You can search your entire computer(This Mac) or the folder that was selected in the Finder when youstarted your search. New search results begin to appear after youselect a location.
step_3.gif Refine the results by specifying search criteria.
Specifying criteria in a search window step_4.gif Click the Time Machine icon in the Dock.
If Time Machine isn’t in the Dock, look for it in the Applications folder.
step_5.gif Use the arrows and the timeline along the right edge of your screen tobrowse through the Time Machine backups. Your search is performed inevery window.
step_6.gif When you find the item you want to restore, select it and then click Restore.
8/26/2008 5:38:17 PM • Cavalry Storage... • Answered on Aug 26, 2008
Broken Fan
You should be able to open up your external hard drive enclosure, find the right size fan, and order another one from almost any online store for cheap. You may even be able to go to some computer store nearby you and you may be able to get one there.
6/18/2008 4:33:06 PM • Cavalry Storage... • Answered on Jun 18, 2008
Cavalry hard drive gets error message
click start control panel administrative tools computer management then select event viewer depending on what operating sytem you have this may vary extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured you might be able work your way through the problem if it's a program file you might uninstall the program restart your computer then reinstall some of these files/software hope this helps
5/9/2012 9:43:17 PM • Cavalry Storage... • Answered on May 09, 2012
I have an unused internal 500 hard drive in an enclosure. Will upgrading it to a USB 3 enclosure do anything?
sadly we can not tell you if it will even work for what you want to do
11/27/2020 12:33:48 PM • Cavalry Storage... • Answered on Nov 27, 2020
Constant beeping from Cavalry external HD
Can't say exactly what it means technically speaking, but my experience with such a problem is that the drive is 'dead'. Of course trying it on another computer would be constructive.
12/15/2017 2:17:42 AM • Cavalry Storage... • Answered on Dec 15, 2017
My black calvary external hard drive won't turn on.
Would be great if the next time you also place the model number, because Cavalry makes dozens of different drives. When the bleu light does not go on, you have to assume the drive is not getting power. If the drive has only one cable, (small drives like 2,5 inch most of the time only have one cable) it could be the USB cable is defect and can't give through the 5 Volt coming from the computer USB connector. It also could be the 5 Volt supposed to be in the computer has gone. If you have to connect an external power supply, with a small cable to the drive, I would check the power supply. A 5 Volt 2 A supply, with the round plug can't be that expensive. If both don't work, it also could be inside the housing of the drive is something defect. If you need to have the data on the drive, you always could but an universal USB connection for hard drives. I have one for IDE and E-SATA, in the box came a set power cables and a power supply, but that one was almost 50 dollar. There are cheaper ones on the net. Be aware drives don't live forever and make sure you always have at least two backups. (that is more than one origin; and one back up)
6/17/2014 12:05:52 PM • Cavalry Storage... • Answered on Jun 17, 2014
Error message says I don't
Hi there, It sounds like your network administrator has locked your ability to write to certain folders. If this is a home hard drive, the only way to fix this would be to completely reinstall windows. If it's a work computer, you need to talk to your IT Department. -Alex
8/13/2011 2:15:34 AM • Cavalry Storage... • Answered on Aug 13, 2011
My computer not recognizing hard
check the power and data cables and try to but the bios into the default sittings
8/5/2011 1:30:26 PM • Cavalry Storage... • Answered on Aug 05, 2011
CAUO37500 Lite's on but nobody
im not sure how bad your hard drive is but if it works on another computer
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x right click to reinstall drivers or if you can see your usb but its not working ports(com&lpt)right click update driver sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable, just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated hope this helps also you could run the chkdsk utility click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive another way of running the chkdsk utility click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart do not do anything while the chkdsk utility is in progress any input may damage your computer then defragment your hard drive also you might download and use this registry cleaner it is totally free to use http://download.cnet.com/ccleaner/
6/18/2011 8:10:59 PM • Cavalry Storage... • Answered on Jun 18, 2011
Cavalry Storage Cavalry CADB001U32 1TB 7200RPM USB 2.0 3.5-Inch External Hard Disk Drive 500 GB Hard Drive Logo
Popular Tags
17 questions posted
Top Cavalry Storage Computers & Internet Experts
Marvin
Marvin
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Cavalry Cavalry Storage
  • Cavalry Cavalry Storage
Most Popular Question
calvary 1tb usb 2bay external hard drive
  • Computers & Internet
