20 Most Recent
LaCie Hard Disk 500GB with Hi-Speed USB2.0 500 GB USB 2.0 Hard Drive Questions & Answers
OWNER MANUAL
Go to Lacie.com, support and downloads and then choose the product that you have. There will be an option for you to download the owners manual for your drive.
LaCie Hard Disk...
Answered
on Nov 04, 2013
I cannot drop files from my laptop to my lacie n2870. What is the problem?
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured Right click on the error message select properties you will see all details about the error or click start type in event viewer press ENTER you might be able work your way through the problem
LaCie Hard Disk...
Answered
on Jan 14, 2013
The disk is inaccessible and the only wa
Try using the Recuva program.
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
- Put the memory card into an USB card reader and plug it into the USB port in your computer, then run the Recuva program.
- Simple to use interface - just click 'Scan' and choose the files you want to recover
- Easy to use filter for results based on file name/type
- Simple Windows like interface with List and Tree view
- Can be run from a USB thumb drive
- Restores all types of files, office documents, images, video, music, email, anything.
- Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
- Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
- Restores files from external ZIP drives, Firewire and USB Hard drives
- It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuva
http://download.cnet.com/Recuva/3000-2242_4-10753287.html www.filehippo.com/download_recuva
LaCie Hard Disk...
Answered
on Nov 10, 2012
Hi. I have a LaCie Hard Drive designed by Poulton
I have the same one. The power supply I have says input 100-240V output is 24W 12V 2A.
I'm replacing the power supply but my big problem is not knowing the polarity of the tip There is no sticker on the hard drive itself or on the power supply (that I suspect is fried). Can anyone help?
Lisa
LaCie Hard Disk...
Answered
on Mar 20, 2011
I cannot connect to my computer, and i keep
You hard drive has crashed. The spindle on it has broken or is breaking so please don't use it!!! If you absolutely need the information on it then you should take it to a computer store where they can recover some of the data. Remember the Hard Drives will occasionally break. If you are adventurous then take the HD out of it's case attach it to your computer's MB and Powersupply then boot up and use a utility to try and find out whats wrong and if you can restore files on it. Use a linux disk to help.
LaCie Hard Disk...
Answered
on Mar 07, 2011
My XP does not appear when connected through the
shouldn't need a driver if you got windows xp or higher. it should automatically install as a USB storage device.
is this new? if so you will need to format the hard drive if its not formatted already.
you can also check manager and go to storage device and see if the volume is getting a proper device letter.
do this by right clicking on my computer and choose manage. go to storage device and look for the hard drive. right click on it assign drive letter.
LaCie Hard Disk...
Answered
on Mar 06, 2011
I have an N2870. All
Is it spinning? If its not, then your hard disk might be dying, but you can still save the data on it. Usually what i do is try to shake it until it starts spinning again. then connect it to your pc again.
LaCie Hard Disk...
Answered
on Mar 02, 2011
