20 Most Recent
Seagate Barracuda 7200.10 ST3250310AS SATA Hard Drive Questions & Answers
Hard disk detection problem
ALL hard drive eventually fail, I suspect yours is failing, I strongly suggest you backup all your data. Here is a free software that will tell you about your hard drives health.
https://crystalmark.info/software/CrystalDiskInfo/index-e.html
10/5/2017 2:44:43 PM •
Seagate...
Answered
on Oct 05, 2017
Hard disk clicks won't spin
Clicking Hard drive When a hard disk makes a clicking sound and the computer does not detect it then the hard disk is faulty. This is commonly known as "The click of death". There is no way of fixing this hard drive, if you need to recover your data, then there are companies that can recover data off faulty hard drives BUT it will cost you an arm and a leg for their services.
10/21/2012 9:51:09 AM •
Seagate...
Answered
on Oct 21, 2012
I had four broken DVRs of same type, I want to use
The SATA RAID interface needs to be compatible with SATA revision V2.0. Check the drives with the Seagate diagnostic tool (download it from Seagate) for correct operation. This will also check / test the SATA interface. Connect the drives directly to a PC with SATA interface to do this. If proven OK then use the RAID board.Possibly there's a way to downgrade to SATA-1 using a Seagate tool.
7/9/2011 1:25:21 AM •
Seagate...
Answered
on Jul 09, 2011
I feel a burning smell
If the control board actually burned, the only way to get data off of the drive is to replace the control board. The only way to do that is to use a clean room, clean suits and replace the control board.
I'd suggest contacting a local data recovery service, they have these items available.
It's going to be upwards of $500 to recover to data, probably not worth it.
5/2/2011 3:41:44 AM •
Seagate...
Answered
on May 02, 2011
Old computer with windows xp won't boot - how can
You should be able to put the old hard drive in the new computer and connect it as a secondary drive. That all depends on the type of interface the new computer is using. Most new computers use SATA inferface for HDD now. You're old drive might be IDE. in which case you can't add it to new computer unless it also has IDE interface on new MB. If no IDE interface on new MB, you can use USB 2.0 to IDE or Serial ATA Drive Adapter Cable from Cablestogo.com to connect your old drive via USB.
4/1/2011 7:11:52 PM •
Seagate...
Answered
on Apr 01, 2011
I had windows vista and
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
3/18/2011 1:43:09 AM •
Seagate...
Answered
on Mar 18, 2011
I updated windows vista to windows 7. the upgrade
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
3/18/2011 1:36:24 AM •
Seagate...
Answered
on Mar 18, 2011
Please share image and location of TVS diode in ST3120827AS seagate hard disk circuit board
For the Seagate hard disk model ST3120827AS, the TVS diode is typically located on the circuit board (PCB). TVS diodes are designed to protect electronic circuits from voltage spikes and transient events. They are usually small, with two leads, and look like small cylindrical or rectangular components.To locate the TVS diode on the circuit board, you may need to refer to the hard drive's datasheet or schematic diagram, if available. Additionally, you can try searching for online resources or forums where individuals share information about hard drive components and their locations.Regarding the Cisco Nexus Network Switch , it's important to note that specific details about the internal components, including the location of TVS diodes, may be proprietary and not readily available in publicly accessible documents. For detailed information about the switch's internal components, you may need to refer to Cisco's official documentation or contact Cisco's support
https://www.serverblink.com/n3k-c31108pc-v-cisco-nexus-network-switch/
2/19/2024 8:12:49 PM •
Seagate...
Answered
on Feb 19, 2024
The hard disk not detected
Try downloading TESTDISK and see if the drive is detected on the List within TESTDISK. If it is then you may be able to restore the boot sector within TESTDISK.
5/22/2019 10:07:55 AM •
Seagate...
Answered
on May 22, 2019
Seagate barracuda 7200.9 connect to USB
You will need an external Hard drive adapter case.
This will probably come with driver disk.
If already and external drive it may have internal firmware which talks directly to the PC.
Just install drivers, if any, and plug unit in.
Follow screen prompts.
11/23/2017 3:49:02 PM •
Seagate...
Answered
on Nov 23, 2017
Can a power interrupt during hard drive installation cause a "Boot manager missing" message?
You do not say what OS you were installing, and Windows limits what you can do with the hard drive during installation.
As you have found out, any power interruption during an installation will likely corrupt the process and make the system unbootable.
If you can restart the install at the very beginning that may work for you. However, I believe the simplest fix will be to use a live system bootable disk and erase the corrupted partition table on the drive then restart the install as if it were a brand new hard drive.
For that type of recovery I use gparted, which can be downloaded for free from
http://gparted.org/livecd.php
Gparted live can be used on CD, hard disk, USB, or even pxe boot. I would delete all the existing partitions that were created during the failed install, then restart the install from the very beginning as if it were a new disk.
3/10/2017 6:40:44 PM •
Seagate...
Answered
on Mar 10, 2017
