20 Most Recent Westclox 70026A LCD Atomic Digital Alarm Clock Questions & Answers
How do I set day and date? All else is set
SETTING THE TIME Note: When the signal is being received (as indicated by the atomic indicator signal) you will not be able to make any setting or adjustments to the clock. 1. To begin setting the clock, press and hold the MODE button located on the back of the clock for 3 seconds to enter the TIME setting mode. 2. The HOUR digits on the display will begin to flash. Press the UP or DOWN button to set the HOUR in one hour increments. Press the UP or DOWN button as necessary until the correct hour is displayed. Note: If you are in the 12 hour time format, be sure you are in the correct AM or PM time period. When the "PM" indicator appears on the display, the time displayed is in the 12 hour period between 12:00 noon and midnight. 3. Press the MODE button again to exit the HOUR setting and enter the MINUTE setting mode. 4. The MINUTE digits on the display will begin to flash. Press the UP or DOWN button to set the MINUTES in one minute increments. Press the UP or DOWN button as necessary until the correct minute is displayed. 5. Press the MODE button again to exit the MINUTE setting and enter the SECONDS setting mode. 6. The SECONDS digits on the display will begin to flash. Press the UP or DOWN button to reset the SECONDS to zero. 7. Press the MODE button again to exit the time setting mode. The clock will automatically return to the normal time display mode. Note: If no settings are made within 30 seconds, the clock will automatically return to the normal time display mode. If this happens, you will need to start the time setting procedure again from step SETTING THE CALENDAR 1. Press the MODE button (located on the back of the clock) twice (do not hold the mode button) to display the CALENDAR. Note: The YEAR icon will be shown on the display indicating you are in the year display mode. 2. Press and hold the MODE button for 3 seconds to enter the CALENDAR setting mode. 3. The YEAR digits on the display will begin to flash. Press the UP or DOWN button to set the YEAR in one year increments. Press the UP or DOWN button as necessary until the correct year is displayed. 4. Press the MODE button again to exit the YEAR setting and enter the MONTH setting mode. 5. The MONTH digits on the display will begin to flash. Press the UP or DOWN button to set the MONTH in one month increments. Press the UP or DOWN button as necessary until the correct month is displayed 6. Press the MODE button again to exit the MONTH setting and enter the DATE setting mode. 7. The DATE digits on the display will begin to flash. Intermittently pressing and releasing the UP or DOWN button to set the DATE in day one increments. Press the UP or DOWN button as necessary until the correct date is displayed. Note: The day of the week will automatically set according to the month, date, and year. 8. Press the MODE button again to exit the calendar setting mode. The clock will automatically return to the normal time display mode. Note: If no settings are made within 30 seconds, the clock will automatically return to the normal time display mode. If this happens, you will need to start the calendar setting procedure again from step 1
12/9/2014 11:10:39 PM • Westclox 70026A... • Answered on Dec 09, 2014
How to change volume of alarm
Volume of the alarm is usually standard. Can't be controlled.
8/12/2014 4:36:51 PM • Westclox 70026A... • Answered on Aug 12, 2014
Westclox 80231NS user-manual
3/13/2023 8:12:10 PM • Westclox Audio... • Answered on Mar 13, 2023
How do I set the time on a Westclock tech model clock?
They all have model numbers. The names are kinda generic.
2/24/2023 5:18:57 AM • Westclox Audio... • Answered on Feb 24, 2023
Westclox Radio Alarm model 80205CN. Do you have a manual for it please?
Question edited for clarity. Contact the maker site. It is not in any of the manual sites. https://westcloxsource.com/user-manuals/ ..
2/24/2023 5:10:43 AM • Westclox Audio... • Answered on Feb 24, 2023
I have a Westclox model #15600QA, when set time for alarm is reached, I do not hear alarm and the clock's second hand stops functioning.
It sounds like there may be an issue with the alarm function and/or the clock movement in your Westclox model #15600QA clock. Here are some steps you can try to troubleshoot the issue:
  1. Check the battery: Ensure that the battery in the clock is fresh and properly installed. A weak or dead battery can cause the clock to stop functioning or the alarm to not sound.
  2. Check the volume: Make sure that the volume of the alarm is turned up and not muted. There may be a switch or dial on the back or side of the clock to adjust the volume.
  3. Check the alarm setting: Ensure that the alarm is set correctly and that the time is set to the correct AM/PM setting. Check that the alarm switch is in the "on" position.
  4. Check the clock movement: If the clock's second hand stops functioning, this may be a sign that there is an issue with the clock movement. Try resetting the clock and see if the second hand starts moving again. If it does not, there may be a problem with the clock's gears or other internal components.
  5. Contact Westclox support: If none of the above steps resolve the issue, it may be best to contact Westclox support for further assistance. They may be able to provide additional troubleshooting steps or suggest repair options if the clock is still under warranty.
Note: Before attempting any repairs or opening the clock, make sure to read the instructions and take proper safety precautions. If you are unsure of how to proceed or do not feel comfortable making repairs yourself, it is best to seek the help of a professional clock repair service.
2/23/2023 3:45:48 PM • Westclox Audio... • Answered on Feb 23, 2023
How to set Westclox 0717?
1/19/2023 2:24:23 PM • Westclox Audio... • Answered on Jan 19, 2023
Why would a manual wind up westclox alarm clock not respond when wound?
Spring broken! Gears broken! Overwound!
5/20/2020 12:51:47 PM • Westclox Audio... • Answered on May 20, 2020
Does westclox model 70028 time resets when unplugged
I doubt it though you can download a user manual and check in there. There is a facility for a backup battery but the purpose of that is to keep the clock ticking over in the background in the case of a power cut. I doubt the backup battery would be enough to power any more than essential circuitry.
8/16/2019 1:42:59 AM • Westclox Audio... • Answered on Aug 16, 2019
Have a beautiful Westclox Big Ben 1964 wind up clock. The person said he believed it was wound too tight. According to the owner:The Big Ben doesn't run (is wound tight), and the alarm only clicks when the alarm hand is advanced to the time setting.
Sorry to say that clock repair is not easy and is a lost art. You may want to see if you can locate one locally that can fix it. The only other chance you have is to open the clock and look for the winding spring and the pawl that holds it and release the tension by holding the pawl back as you put torque on the winding stem, then release the stem slowly and then release the pawl.
4/16/2019 4:14:18 PM • Westclox Audio... • Answered on Apr 16, 2019
I took my dialite westclox bold2 apart to repaint it. Some how I forgot where the electric wires connect.
Could you provide a close up of the clock unit itself? There may be a couple of holes in the clear plastic where the wires can be inserted into.
4/3/2019 11:25:49 AM • Westclox Audio... • Answered on Apr 03, 2019
Westclox 70026A LCD Atomic Digital Alarm Clock Logo
8 questions posted
Top Westclox Audio Players & Recorders Experts
nexrad_chris
Ngoro
Are you a Westclox Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Westclox Audio Players & Recorders
Most Popular Question
set day date all else set
  • Audio Players & Recorders
