STRIPED SCREEN OF DEATH
Before it freezes it starts to pixel like crazy then it freezes with a striped screen,
Possible Reasons & Fixes:
* Review your Direct X services:
- Click Start, then click Run.
- In the Open box, type dxdiag, then click OK. 3. This will run the DirectX diagnosis tool.
Failing that check whether there may be a conflict with any of your devices by clicking on your control panel and checking for any exclamation marks against devices.
* Try upgrading the RAM, which is likely to be the cause for issue if everything shows normal in Dxdiag settings. [Note: High graphics games is likely to lead to overheating GPU]
* If you are new to this issue, try
System Restore.
* Try clearing the temp files/cache/history
* Power supply need to be more than 500kv, cooling fans play a pivotal role
[Overheating : CPU or the GPU]
* Change your Screen
Refresh Rate
Other Suggestions:
1.Download and Install the Latest VGA Driver Update
2.DirectX 9.0c Reinstall
3. Buy a New Power Supply
4. Buy a New Fan for Your Proccesor and Check Your VGA Drive Fan Also Clean up the whole CPU
