20 Most Recent Brookstone TimeSmart Self-Setting Alarm Clock Radio Questions & Answers
Setting the time on the brookstone alarm clock model 4511
How do I set the time on my clock
6/19/2021 12:02:07 PM • Brookstone... • Answered on Jun 19, 2021
How do i connect my whisper nx headphones to my TV
Hello Mr. Abramowitz This one https://manuals.brookstone.com/306612p_manual.pdf or this one https://manuals.brookstone.com/725793p_manual.pdf As it says 'Connected', I wonder if there is a Mute button on the headphones or on the television, or that you have volume on either device set to Zero? That would leave you connected but not hearing sound. Or you can go into the television settings and remove the entry for the headphones and re-pair the headphones to it. https://www.google.com/search?q=Brookstone+Whisper+NX+BSNCH101+manual ..
1/11/2023 6:15:05 PM • Brookstone Audio... • Answered on Jan 11, 2023
My brookstone outdoor wireless speaker does not work on just battery power....never has
There are a few potential reasons why your Brookstone outdoor wireless speaker may not be working on battery power. Here are a few things you can try:
  1. Make sure the battery is fully charged. If the battery is not fully charged, it may not be able to power the speaker.
  2. Check the battery connections. Make sure the battery is properly seated in the speaker and that the connections are clean and secure.
  3. Try a different battery. It's possible that the battery you are using is faulty or has simply reached the end of its lifespan.
  4. Check for any visible damage to the speaker or battery. If you see any signs of physical damage, this could be the cause of the issue.
  5. Contact Brookstone for further assistance. If you have tried all of the above steps and the speaker is still not working on battery power, you may need to contact the manufacturer for further assistance.
I hope this helps! Let me know if you have any other questions.
1/8/2023 4:55:20 AM • Brookstone Audio... • Answered on Jan 08, 2023
2answers
How do you change the time from a 24hr clock to a 12hr clock. For example clock says 19:50 instead of 7:50 pm on a Brookstone 5-in-1 Sensor Clock.
Selecting 12- or 24- Hour Mode While in the Time screen, press or to select either 12- or 24-hour mode. If 12-hour mode is selected, PM displays for the afternoon/evening hours. AM does not display for the morning hours http://origin-www.brookstone.com/webassets/pdf/740687p_manual.pdf
6/25/2022 3:01:43 PM • Brookstone Audio... • Answered on Jun 25, 2022
How do I change my Brookstone 399923 clock from military (24 hour) time to standard (12 hour) time please?
Try this Setting the 12/24 time format The 12 hour format is set as the default. To change the 12/24 hour time format, open the CONTROL COMPARTMENT COVER on the bottom of the clock and adjust the 12/24 TIME FORMAT switch to the desired format. Close the CONTROL COMPARTMENT COVER.
3/26/2022 1:12:03 AM • Brookstone Audio... • Answered on Mar 26, 2022
I have a 9 Pin Mini Din Minidin Male to Male Cable Non Standard B Type I where do i connect it on my Brookstone acousticlear 3 cd music system?
If it is the cables on the left of the image and enlarged in a later image, I would guess it connects the Bass Sub to the CD unit. https://www.ebay.com/itm/164776264603 Another cable for sale https://picclick.com/Replacement-Brookstone-Wafer-Thin-CD-System-9-pin-Cable-373183015603.html no manual available, not even from Brookstone. https://www.google.com/search?q=brookstone+acousti+clear+3cd+manual You could contact them https://www.brookstone.com/pages/manuals ..
1/7/2022 4:54:31 AM • Brookstone Audio... • Answered on Jan 07, 2022
How to fix a CD Play that stops in the middle of a track
Probably dirty laser optics, especially the tracking optic. Go to Walmart or Amazon and get a CD cleaner disc. It has small brushes that clean off dust.https://www.staples.ca/products/786397-en-staples-cd-dvd-drive-cleaner..
10/30/2021 7:45:32 PM • Brookstone Audio... • Answered on Oct 30, 2021
2answers
Hi. I cannot figure out where the ac power goes into my Brookstone Wafer-thin cd system (2005) there is no where on the system to insert the power cord.
From set up manual Setting up the system takes no time at all. Connect the subwoofer to the main unit with the provided cable. The NXT speakers connect directly to the subwoofer with color-coded cables for left and right. An FM antenna is included and can be connected easily to the rear of the unit (the AM antenna is built in.) Finally, the subwoofer gets plugged into the wall for AC power and the unit can be powered up. If this takes you more than 5 minutes, call your Dad and ask for help, you're probably over-thinking it. There is no setup in terms of volume or bass management configuration as the sub handles all crossover functions as well as volume balancing between itself and the NXT speakers. You can get a copy from manufacturer or online search
3/15/2021 12:25:03 AM • Brookstone Audio... • Answered on Mar 15, 2021
Setting Brookstone floating alarm clock
find a manual
12/4/2019 8:43:43 PM • Brookstone Audio... • Answered on Dec 04, 2019
Speaker not working no sound
Hi Gina, your Brookstone, I could have a power supply problem, consult a specialized technical service Regards Franco Dosil Hola Gina, tu Brookstone, podria tener un problema de fuente de alimentacion, consulta en eun servicio tecnico especializado Saludos Franco Dosil
9/3/2019 4:52:46 PM • Brookstone Audio... • Answered on Sep 03, 2019
0answers
Brookstone TimeSmart Self-Setting Alarm Clock Radio Logo
Popular Tags
2 questions posted
Top Brookstone Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
 Mike M
Mike M
Are you a Brookstone Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Brookstone Audio Players & Recorders
Most Popular Question
setting time brookstone alarm clock
  • Audio Players & Recorders
