20 Most Recent Sansui HDLCD3200 TV Questions & Answers
you do not have a CRT in your flat panel set.. What you might have is your color setting to high causing the bleed or your
T-con board is bad , but first turn down your color if that does not do it have a tech replace your
T-con board
Sansui HDLCD3200... • Answered on Jul 26, 2017
Got no power on my tv need sone advice as change fuse still not working
Sansui HDLCD3200... • Answered on Apr 27, 2017
ignorant untrue answer. Many monitors and especially older TV/Monitors of odd makers (Sansui for a FACT) are NOT plug and play and windows has no idea what resolutions it supports. Really, all you can do is go under advanced in your adapter settings and try different resolutions and refresh rates. If you can't see - quickly hit escape. Find the best one that works for your monitor.
Sansui HDLCD3200... • Answered on Jan 23, 2015
Hello E.C. Wait Your parts can be found simply on amazon, click here and take a look: Amazon com sansui tv parts. Wish you best of luck. Donald
Sansui HDLCD3200... • Answered on Jan 10, 2015
Its cost will depend on its capacitance value, and rated voltage. Gopakumar Gopalan Google
Sansui HDLCD3200... • Answered on May 16, 2014
The TV has a resolution of 1366 x 768 for mine, I set the display properties to1280x768 the closest you can get to the actual 720p resolution.
Sansui HDLCD3200... • Answered on May 23, 2012
This is a common fault solution which can be checked and corrected by you assuming that there is no component failure . There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Sansui HDLCD3200... • Answered on Aug 02, 2011
Sorry,tv it is not worth as a whole tv anymore,this tv now only can be used as a salvage tv for it electronic boards for other tvs needs only now.Because tvs LCD screens panels are in very limited in productions buy the tvs corporations.The tv LCD screen panel is 90% important to tv it functions and u can buy it from by those tvs corporations only.They will sell it to u,but they will charges the selling prices for it the same as a new tv.
Sansui HDLCD3200... • Answered on Jul 08, 2011
Does your laptop feed sound through the HDMI connection? You may have to use the HDMI 1 jack on the HDLCD3200. Change the HDMI setting in the audio menu on the tv to DVI and run a seperate audio cord from the laptop to tv. I hope this is helpful
Sansui HDLCD3200... • Answered on Jun 07, 2011
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
Sansui HDLCD3200... • Answered on May 18, 2011
the power supply of your TV must be check.the power output of the power supply suppose to be 12 volts for audio,24 volts for the backlight lamp and 5volts for the main CPU. use a multimeter to measure the voltage In the case of your TV it seems only 5 volts is present that is why you have a power indicator lit....open the back cover of your TV and measure the power supply.power supply board is where the power cord is connected...
Sansui HDLCD3200... • Answered on Apr 19, 2011
I am an electronics tech so i know that finding spare parts for a tv can be very difficult. Your best bet is to try to purchase the board from Sansui. If Sansui cannot help you ebay is a great place to find spare parts.
Sansui HDLCD3200... • Answered on Mar 03, 2011
Click on the link that is telling you to activate then there is a phone number call and they should walk you it takes 6 to 9 minutes and you be up and running normal.
Sansui HDLCD3200... • Answered on Nov 01, 2010
You need to use the TV's remote control, it will have an INPUT / SOURCE / MODE button, one of those three. Just hit that button and it will take you through the inputs, one of which is AUX 1.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks,
Tim
Sansui HDLCD3200... • Answered on Oct 15, 2010
try to look for all datasheet.com it might help you.
Tries websites like Shopjimmy.com,Ebay.com to buy the refurbish Tuner board.
Sansui HDLCD3200... • Answered on Jun 07, 2010
Sansui HDLCD3200 TV Logo
48 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Muntejaya Ginting
Muntejaya Ginting
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
spare parts sansui tv
  • Televison & Video
