20 Most Recent
Hannspree HANNslounge 32 in. LCD HDTV 32 Questions & Answers
I have a 42'' Hannspree
I sugest that you should contact service provider or return the unit where you bought your tv. so your warranty will not be void. Good day and best regards.
9/2/2011 9:56:58 AM •
Hannspree...
Answered
on Sep 02, 2011
Although we have no additional
Hi rinkejus.
http://www.hdtvreview.com/pdf/hannspree-hannslounge-32-manual.pdf
This link is the user manual for your tv. If you already have it, don't bother downloading it. Follow page 75 and 76, which describe the audio settings. Play with the equalizer until, hopefully, you find a setting you are happy with. You can also play with the sound effect, as music tends to "broaden" more readily than speech. Also, if you are set on surround, most of the speech will be in the centre channel - which isn't there because it requires an external speaker.
From what you describe, you don't have a fault of any kind, just the features of your tv are having an undesired effect. Good luck. Please vote 4 hands if this was useful.
1/6/2011 2:53:25 AM •
Hannspree...
Answered
on Jan 06, 2011
Trying to put volume onto Sky remote handset from
Well you can please follow the below link to get you code -
http://www.sky.com/portal/site/skycom/skyhelpcentre/producthelp?nodeId=73a6e9e0-0ade-4eed-810b-cec670799bcc&articleId=11320303
Thanks for using FixYa!!
Good Luck!!
3/27/2010 7:05:56 PM •
Hannspree...
Answered
on Mar 27, 2010
When turned on, no picture, sound or response. LED is OK
I had a similar problem with my HANNSLounge 32", the screen switched on with green light but none of the front panel buttons worked (screen is black apart from showing the input source in the top left).
After powering off numerous times I tried starting up with a blank SD card in the reader and the tv cycled between red green and blue screens and then reset itself. (Some sort of firmware restore?) After which point I had a working screen again! (Will have to see how long it lasts for!)
12/19/2009 3:59:53 PM •
Hannspree...
Answered
on Dec 19, 2009
No pricture on 32
If the TV still switches on, and you get sound, then it could be 1 of 2 things.
The PSU, less likely.
The Inverter, more likely.
It is difficult to determine which is faulty without some test equipment etc.
I hope that helps.
3/28/2009 3:57:28 PM •
Hannspree...
Answered
on Mar 28, 2009
Hannspree 42 lcd right side is showing ghost picture
The issue you are experiencing with your Hannspree 42 LCD TV could be caused by a few different things, such as a loose cable connection, a faulty T-con board, or a defective panel.
Here are a few steps you can try to troubleshoot the issue:
- Check the cable connections: Make sure that all the cables connected to your TV, especially the ones connected to the right side of the TV, are firmly plugged in.
- Power reset: Try turning off your TV and unplugging it from the power outlet for at least 10-15 minutes, then plug it back in and turn it on again.
- Swap inputs: If you are only experiencing the ghosting on one input, try swapping the input with another one to see if the issue persists.
- T-con board: If none of the above steps resolve the issue, it is possible that the T-con board is faulty. The T-con board controls the timing of the image displayed on the screen and is often the culprit of ghosting issues. A technician can diagnose and replace this board if necessary.
- Panel: If the above steps don't resolve the issue, it is possible that the LCD panel itself is defective. This is less common but can happen over time. Unfortunately, replacing the panel can be costly and may not be worth it on an older TV.
If none of the above steps resolve the issue, it may be best to contact a qualified technician to diagnose and repair the issue.
2/28/2023 1:47:00 PM •
Hannspree...
Answered
on Feb 28, 2023
How to Program hannspree remote to hannspree tv
To program a Hannspree remote to a Hannspree TV, first turn on the TV and then press and hold the "Code" button on the remote until the LED light turns on.
Next, enter the four-digit code for the TV using the number keys on the remote. If the TV turns off, press the "Code" button to save the code. If it doesn't turn off, try another code until you find one that works.
If you cannot find the four-digit code for your Hannspree TV, you can try using the code search feature on the remote. To do this, follow the steps for programming the remote but instead of entering a code, press and release the "Code" button and then press the "Power" button repeatedly until the TV turns off. Then, press the "Code" button to save the code.
If you are having trouble programming the remote, make sure you are aiming the remote directly at the TV and that you are not too far away. Also, check that the batteries in the remote are fresh and properly installed.
If you accidentally program the remote to the wrong TV or if you want to program it to a different TV, you can reset the remote to its default settings by pressing and holding the "Code" button for at least three seconds until the LED light turns off. This will erase any previously programmed codes.
2/14/2023 10:49:36 AM •
Hannspree...
Answered
on Feb 14, 2023
Hannspree TV tuning from aerial problem.
do you mean if you hooked up the tv with the aerial antenna can not get any channel? ok if just a white raster only and doesn't scan or tuned even manually and auto search, the cause is bad tuner.
3/10/2022 6:57:09 PM •
Hannspree...
Answered
on Mar 10, 2022
How do i factory reset hannspree sv32amub tv
To do a factory reset, you have to enter its Service Mode. If you wish to get some details; check the sites linked here.
https://elektrotricks.blogspot.com/
https://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important
Search the site by type in the Brand Name of your set, in its search bar at the right side column, and press enter. See it in by Webview with mobile or by desktop. Mobile View has no search box.
8/3/2021 2:40:08 PM •
Hannspree...
Answered
on Aug 03, 2021
