20 Most Recent GPX KCL8807DT TV/DVD Combo Questions & Answers
try the TCL tv remote it work like it was made for that tv word on the ground, RCA it is the same company.
GPX KCL8807DT... | Answered on May 18, 2018
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
GPX KCL8807DT... | Answered on Nov 22, 2014
It's not a channel. You should select the input to TV to HDMI. Refer its user manual, please.
Electro help
GPX KCL8807DT... | Answered on Sep 21, 2014
YOU NEED HELP WITH THOMPSON (RCA-GE) GOOD LUCK--worst company for support or parts or anything.
Only suggestions are if a Combo use it with the Owner manual--could try to GOOGLE the model number for information and research it with key words Model "manual" "firmware (or) software" etc.
GPX KCL8807DT... | Answered on Apr 03, 2012
Unfortunately, what you're describing is a repair issue. You won't be able to address the problem with troubleshooting. There is a part inside the TV that needs to be replaced. If you're under warranty, this will cost you nothing. If you're not under warranty the cost will likely be a minimum of $200 parts and labor. However, be warned that the cost could be considerably higher. You should call the manufacturer for your full range of options.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
GPX KCL8807DT... | Answered on Aug 04, 2009
Hey Bosie Mike 3,
If you missed something in the manual so did I.
I was just pouring over the instructions and I don't see anything for a vol lock or anything of that nature. I can only assume 17-18 is the "standard" vol for the unit, and defaults to it when you turn it on.
Wish I could help more.
Jon
Go Ahead. Use Us.
GPX KCL8807DT... | Answered on May 13, 2008
Obviously you should check the power. plugs, fuses, and GFI switches Incase they tripped.
GPX Televison &... | Answered on Oct 03, 2019
GPX KCL8807DT TV/DVD Combo Logo
Popular Tags
20 questions posted
Top GPX Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Steven Wander
Steven Wander
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • GPX Televison & Video
Most Popular Question
screen goes blank
  • Televison & Video
