20 Most Recent Philips 42HF7444T 42 in. Plasma TV Questions & Answers
Samsung LCD Flatscreen only shows lines of color or purple dots
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size. Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
6/18/2017 1:43:34 PM • Philips... • Answered on Jun 18, 2017
Electricity came back on after power outage and
If your TV was not connected to a surge protector, it may be damaged. If you still have your warranty, check if it covers power surges.
3/2/2011 11:16:44 PM • Philips... • Answered on Mar 02, 2011
I have a Dell W3201C 32
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi
Most likely a power supply component has aged and thus changed value and/or failed. Take it to a reputable repair person.
3/13/2010 11:04:13 PM • Philips... • Answered on Mar 13, 2010
The picture does not come up. Just shades of color
FIRST DEPENDING ON WHAT TYPE OF TV IS HOW TO GO ABOUT TROUBLESHOOTING IT. BUT IT SOUNDS LIKE YOUR BULB/CRT/SCREEN LCDS MIGHT NEED TO BE REPLACED OR FIXED OR RE-JUVED. AGAIN THIS ALL DEPENDS ON WHAT TYPE OF TV YOU HAVE.
2/20/2010 5:12:24 PM • Philips... • Answered on Feb 20, 2010
Shows no picture but has sound its a tedelex 42 inch
if you had no prior ideas about plazma tv . then call to some experienced person so that he can help you. oterwise take to the repair center .
12/7/2009 2:29:05 PM • Philips... • Answered on Dec 07, 2009
Why do i have red lines on my philips plasma tv?
if the lines are going horizontally across and look like someone took a thin magic marker and marked across the screen, you have one of two problems, either some scan ic's have failed or you have a flex cable coming loose from the panel. Either way it will require repair. If it is the flex cable the cost to repair will be beyond the tv's worth because the whole panel needs to be changed to fix this. If it turns out to be the scan ic's, they can be changed or the board the ic's are on may be changed depending on how the repair is approched by the tech. But the cost would be reasonable around 200 to 250.
Good luck
9/3/2009 3:35:11 AM • Philips... • Answered on Sep 03, 2009
Philips Plasma NO LIFE
I had the same problem (with 42FD9954/17S) that when turned on the unit, the green LED turned off and came back to red again some time later. I kept turning it on and once it went to a clicking relay sound and blinking green LED with it. It did that for a while and stayed turned on. I noticed that it is temperature sensitive. Colder the room is more often does it. Used a hair dryer and blown hot air into the unit at the left bottom grills. It helped and started to tun on quicker. Later it has deteriorated so bad that I took it a part and after several ice spraying test showed that on the middle big board (power board) there was an electrolyte condenser went bad. It is the one one which is at the middle, bottom center of the board near the fixing screw. There are two of them (cylindrical objects). The left one was the culprit. However when I fixed it, it turns on immediately but goes blinking red after that. Phillips say it is a static discharge problem. I might blown something when soldering the parts. I don't know what. Any ideas?
4/15/2009 2:02:17 AM • Philips... • Answered on Apr 15, 2009
Phillips 37 HDTV, have audio but no video.
check all the cables, are they plugged in correctly. if so its broken im affraid.
12/7/2008 7:15:43 PM • Philips... • Answered on Dec 07, 2008
Tv switching off on its own without any one tourching it
I have slightly different problem. The TV "switched" off suddenly when I changed the channels too many times. Will need to turn off the main switch power off for a while before the TV can be turned on again. A very irritating and mysterious problem. Wondering if there is any fix to this problem?
7/26/2008 2:19:44 PM • Philips... • Answered on Jul 26, 2008
Red line in top corner of screen
Sounds like an IC on the LCD panel went out of TV. Only thing to do is replace panel (it won't go away only get worse) It will probable be cheaper to just get another tv.
4/21/2008 10:04:02 PM • Philips... • Answered on Apr 21, 2008
Philips Z11 TV/VCR Combo. I need the 4 digit universal remote code for TV VCR please.
I don't think you will get that to work, you have two units in one box https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote 'Z11' doesn't seem to be the correct alpha numerical model number. https://www.google.com/search?q=philips+z11+tv%2Fvcr+replacement+remote
Save Code list for future reference Refer to the setup ...
Philips https://www.p4c.philips.com > files > sru4000_17 PDF Save Code list for future reference Refer to the setup procedure below and look up the 3 digit code for your brand of TV, VCR, etc., from the list below. 2 pages Missing: z11 ‎' Must include: z11
Philips 4 digit remote codes for Combo devices - eliztech.com
eliztech.com https://www.eliztech.com > remotes > philips-4digit-co... Four digit code lists for HTIB and TV/VCR/DVD/DVR/SAT/CABLE Combos - Philips universal remote controls. Missing: z11 ‎' Must include: z11
Philips Universal Remote Control Programming Instructions
directutor.com https://www.directutor.com > content > philips-sru210... Program your audio and video devices with Philips Universal remote codes, simple steps for programming Philips universal remote...
3/15/2023 7:29:27 PM • Philips... • Answered on Mar 15, 2023
Philips 49PUS6501/12 (49", 4K, HDR, QLED). Replacing backlight in it.
Help in the videos
3/14/2023 4:44:46 PM • Philips... • Answered on Mar 14, 2023
2answers
Philips tv Model - 21PT3525/V7 I want EHT Number ?
The EHT number for a Philips TV model 21PT3525/V7 can vary depending on the specific version of the TV. However, the EHT number for this model is typically BSC25-0235 or BSC25-0217. It's important to note that replacing the EHT can be a dangerous process, as it involves working with high voltage components. If you're not experienced with electronics repair, it's recommended to seek assistance from a qualified technician who can perform the repair safely and properly.
3/4/2023 1:03:43 AM • Philips... • Answered on Mar 04, 2023
I have a Sanyo remote control and I need the 3 digit code for a Philips tv
default pass code (normally 0000, but also in some device 1234 or 8888 is used).
3/2/2023 12:47:06 AM • Philips... • Answered on Mar 02, 2023
Philips 4k 50put6400 no sound or picture wondering could this be the motherboard?
Sounds more like LED backlight than a main board issue
2/28/2023 9:54:00 PM • Philips... • Answered on Feb 28, 2023
How do I program my Magnavox universal remote to my Philips Magnavox fw530c mini Hi-Fi stereo
To program your Magnavox universal remote to your Philips Magnavox FW530C mini Hi-Fi stereo, follow these steps:
  1. Turn on your Philips Magnavox FW530C mini Hi-Fi stereo manually.
  2. Press and hold the "Code Search" button on your Magnavox remote until the indicator light turns on.
  3. Press the "Device" button on the remote, which should be the button corresponding to your stereo.
  4. Enter the 3-digit code for your stereo. You can find a list of codes for Philips Magnavox products in the user manual for your universal remote or online. If you do not have the manual or cannot find the code online, try entering codes 006, 007, 010, 011, 013, 016, 027, 033, 035, 043, 066, 087, 089, 114, 117, 118, 119, 120, or 123.
  5. Press the "Power" button on the remote to see if the stereo turns off. If it does, you have successfully programmed the remote. If it does not, repeat steps 2-4 with a different code until you find one that works.
  6. Once you have programmed the remote to control your stereo, test out the other buttons to make sure they work as well (such as volume control, track skip, etc.).
Note: If you cannot find a code that works for your stereo, you can also try the "Code Search" function on the remote. This may take some time, but it will automatically search for the correct code until it finds one that works.
2/26/2023 6:54:07 AM • Philips... • Answered on Feb 26, 2023
2answers
I have Philips MCD988 DVD. The screen is not bright as normal, the sound also low, only when I open the DVD lid. The sound surges up for 3 seconds, the screen goes brighter then low again. Help please
This is most likely a problem with the power supply unit. Replacing the power supply should fix your issue.
2/22/2023 7:26:54 PM • Philips... • Answered on Feb 22, 2023
Philips Android TV won't turn on?
A cautionary tale about television repair, but the obvious thing would be the power board as long at you found power at the end of the lead. https://www.fixya.com/support/r29790007-repairing_own_television ..
2/18/2023 1:08:48 AM • Philips... • Answered on Feb 18, 2023
My Philips 55pfl5601/F7 Turns on but turns right off by itself
This issue could be caused by a faulty power supply or a malfunctioning component in the TV's circuitry. It is recommended to contact a qualified technician to diagnose and repair the problem.
2/14/2023 12:24:36 PM • Philips... • Answered on Feb 14, 2023
Philips 42HF7444T 42 in. Plasma TV Logo
Popular Tags
19 questions posted
Top Philips Televison & Video Experts
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Philips Televison & Video
Most Popular Question
electricity came back after power outage
  • Televison & Video
