20 Most Recent Frigidaire FEF366DC Electric Kitchen Range Questions & Answers
We're having the same problem. Oven light works, but plug by oven light switch does not. I changed the screw in fuse (15 Amp) in the oven, although it was blown, it didn't fix the problem.
I will be checking the double breaker on the electric panel tonight, making sure it's getting the full 220v, and if that is good, I will be looking at checking and replacing the clock.
Hope this helps.
Frigidaire... | Answered on Sep 26, 2015
replace the oven temp sensor. it looks like a probe that is in the oven, at the top
Frigidaire... | Answered on Dec 31, 2014
Good Afternoon Friend,
I understand you are trying to change the dual element control on your Frigidaire range, model# PLES389ECH. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your particular appliance and should be able to change the dual element control with ease. Hope this is helpful.
-Best Regards-
WP
Frigidaire... | Answered on Jun 12, 2014
The repair on this stove will be relatively easy then. All you are going to have to do is pull out the stove from the wall and remove the upper part of the back panel where the burner switches are.
Remove the knob and take out the screws that hold the switch to that front panel. Then from there just match up the wires to the new switch off the old one.
This repair will turn out to be pretty cut and dry for you. If you have anymore questions please ask.
Thanks Again,
Bill
Frigidaire... | Answered on Jul 24, 2011
all solutions on the F1 show to replace the EOC control.(error board control)
Frigidaire... | Answered on Jun 09, 2011
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Frigidaire... | Answered on Dec 22, 2010
hi not to be short bot there are no fuses. what the rang doing or not doing? jim
Frigidaire... | Answered on Oct 15, 2010
F0 Electronic oven control failure Replace electronic oven control (also called EOC or clock). F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Frigidaire... | Answered on Oct 04, 2010
I advice you follow the link below to see information therein
http://www.repairclinic.com/Range-Stove-Oven-Troubleshooting#Theclockstopped_electric
Type the above link to see information on how to go about it.
Take care.
Frigidaire... | Answered on Jun 27, 2010
Here is a diagram.
Please let me know if I can assist you further.
Frigidaire... | Answered on Jul 02, 2009
You'll need to replace the burner switch. This happens when the contacts become fused together.
Frigidaire... | Answered on Apr 28, 2009
Frigidaire FEF366DC Electric Kitchen Range Logo
45 questions posted
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
dual element burner glasstop
  • Kitchen Ranges
