20 Most Recent
Bosch SHE45M06UC Built-in Dishwasher Questions & Answers
Water won't drain on last cycle
Remove the filters, look into the sump and at approx 10 oclock you will see a cover held in with a screw (usually a Torx20 screw head but it will come out with a small flat head) This right in the bottom of the sump and not along the rim where the sump meets the tank (do not remove these screw!!) Once the screw is taken out you will be able to remove the pump cover, check for debris, glass fragments or chips of plate etc. With the cover off, set a program and start it, reset as soon as the d/w starts up. This will bring the pump on and if something is trapped underneath the impellor this should 'kick' it out. Replace and secured the pump cover. If this does not resolve the problem, check for blockages at the plumbing or for kinked pipes. Please comment if you need further assistance.
The water is only filling the bottom of the
I'm having the same problem, was told to put in an anti sudzing liquid found near carpet cleaners at lowes... Haunt found it anywhere yet. Tried using dishwasher magic, but that didn't work either bc water never left bottom... Have u found a solution?
Bosch dishwasher model she45m06uc..amking a
Hello, mike
I was trying to help
you out here. Maybe this will help some? I was going back to some customers that asked questions
in the past and it appeared that no one answered them, so I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your dishwasher, from repair
to trouble shooting it,pictures, video's. Just scroll around and you
will see tons of information to almost any question you might have on
your dishwasher. If you go to this link and click around, I am sure you
will find out so much about your dishwasher, you will know more that the
company that made it. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://beta.fixya.com/users/mc1bean
My dishwasher is leaving a soap residue after the
Many possible causes.
My list to trouble-shoot this would be:
- Rinse dishes less before loading--the dirt on the dishes is what the detergent acts upon. You only need to rinse off hard stuff like bones, seeds, toothpicks, and so on.
- Is your rinse-aid dispenser putting out enough?
- Use a little bit less detergent.
- Check the little nozzles in your spray arms. Maybe
they have become blocked. (Sesame seeds are the sort of thing that
cause headaches here.)
- Check drain lines and filters.
- Do you have hard water? Maybe your machine would work
better with a water softener--whether built into the machine, or on the
supply lines for the house.
Bosch SHE45M06UC/50 not draining
drain pump is clogged. probably with a piece off glass or something,you must remove the plastic panel piece at the bottom of unit. must use a torc screwdriver
Dishwasher is not cleaning dishes, glasses are
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not SpinningHow to Buy Appliance Parts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The Heating Element not WorkingDishwasher Maintenanceheatman101
zzmkl
My dishwasher leaks on occasion, and leaves scuz
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...Dishwasher Spray Arms not SpinningHow to Buy Appliance Parts OnlineA bad heating element causes many problems in dishwashers...Dishwasher Problems The Heating Element not WorkingDishwasher Maintenanceheatman101
