20 Most Recent Digital Concepts 54782/54783 Digital Camera Questions & Answers
My camera wont save the images to the camera with
My cards are all over 36 gigabytes your card is not big enough get larger sd card at best buy or target
8/18/2014 3:24:01 AM • Digital Concepts... • Answered on Aug 18, 2014
I don'tknow how to work my camera.
Go to computer and go to tutotials type in your type of camera and they will show you how to work your camera its not hard
8/18/2014 3:19:38 AM • Digital Concepts... • Answered on Aug 18, 2014
No sound on model #0807230007e101011a00
I have this camera and I assumed it didn't have a microphone, should it have sound? shame because the pictures come out great. Mine is broken now though.
10/16/2012 1:59:25 PM • Digital Concepts... • Answered on Oct 16, 2012
Format
Hello
My apologies if this message finds you long after posting this problem , but I am currently working through a backlog of problems that never got answered and hopefully this info can still be of use if not now possibly in future.
Please download Disc Digger HERE. This is a free tool you can use that works very well and there is no installation required, just run the program once you downloaded it.
Once you have connected the memory disk / hdd to the computer , run the program.
On the program , select the dig deep option for accidentally deleted files or dig deeper for a formatted drive. Then select the disk you want to do the recovery on and run the program.
The data will be displayed and you can recover it from there. This will only work if the card has not been used since the data was lost. Save the files to a location on the computer hard drive and not back to the disk it is recovering from as this will overwrite the other pictures that still needs to be recovered.
Some of the properties of the files may become lost in the recovery but the pictures should be fine.
You will also only be able to recover certain file types using this method.
Feel free to ask if you need more assistance.
Kind Regards
Andrea
9/29/2010 2:24:35 PM • Digital Concepts... • Answered on Sep 29, 2010
2answers
No installation disk for my camera
The best place to go is Driversguide.
8/28/2010 10:36:02 AM • Digital Concepts... • Answered on Aug 28, 2010
Card proection?
It meand that the protection of whatever is on your card is activated. Somewhere on the cars will be a small, sometimes a very small switch which you flick across and this stops anything , camera or computer writing to the card. It.s not an electrical switch but just piece of plastic which will block a hole somewhere on the card. Similar to the old 3.5 floppy disk. If the hole is blocked it's protected and if the hole is open you can write to it. Look very closely at the card and you'll spot it. Whatever position it's in, switch it to the opposite direction and the protection warning should vanish.
Get out the glasses:-)
4/7/2010 1:17:53 AM • Digital Concepts... • Answered on Apr 07, 2010
2answers
Digital concepts 4.1 mp model 54782 problems
http://www.downloadatoz.com/driver/item_199703.html
try this webpage
Hope it helps
Have a nice day!
tc
3/30/2010 1:56:37 PM • Digital Concepts... • Answered on Mar 30, 2010
2answers
Using the flash on my digital concepts 5.1 mp camera
press the up button on the control button. looks like a lightening bolt.
3/30/2010 1:51:20 PM • Digital Concepts... • Answered on Mar 30, 2010
No sound on my 7.1 mp camera!
Take a look at the manuals for the 7.1MP Digital Concepts cameras:
7.1MP 72480:
Manual: http://downloads.sakarhelp.com/cameramanuals/72480.pdf
7.1MP 87690:
Manual: http://www.sakar.com/images/resources/download-manual/87690.pdf
3/30/2010 1:44:31 PM • Digital Concepts... • Answered on Mar 30, 2010
My camera is displaying a blue screen with MSDC in
This screen usually comes when it is connected to computer via usb cable. This means, u can readily copy photos to your computer.
thanks,
saumya.
8/3/2009 5:04:54 PM • Digital Concepts... • Answered on Aug 03, 2009
Digital Concepts 3.1 camera cannot be
i need that same help!!!!
7/7/2009 9:28:23 PM • Digital Concepts... • Answered on Jul 07, 2009
2answers
Digital concepts digital camera
This camera is compatible with vista and you dont need any software for this camera to work on vista, its plug in play device. When you connect the camera to your computer it should show up as removable disc under my computer. If its not showing up please try connecting the camera into different usb port and make sure your laptop is fully charged.It will work.
6/9/2009 6:59:11 PM • Digital Concepts... • Answered on Jun 09, 2009
Audio on concepts digital 7.1mp camera
Try accessing the setup menu, options, or menu screens. There may be a mode on the selection dial, or it may be accessible through the video mode.
The camera also may not have audio capabilities.
4/25/2009 8:07:20 AM • Digital Concepts... • Answered on Apr 25, 2009
4answers
Digital Concepts 7.1 megapixel downloads / manual
I need a drivers a digital concepts 5.1 and the his sofware. Thanks.
3/7/2009 6:55:48 PM • Digital Concepts... • Answered on Mar 07, 2009
New 4.1 megapixel....can't use
I am sorry the manuals are not available online, so I suggest to call the manufaturer for the manuals and the # is 877 397 8200 (This is the Sakar Tech Support#)
12/23/2008 4:36:43 PM • Digital Concepts... • Answered on Dec 23, 2008
Can't take pictures.
hi...have u tried removing the lock with the software
or else do try slide lock swith to remove the write protection....assuming that uv tried this...u might as well try another card.
Thanks for using Fixya!
12/11/2008 10:22:28 PM • Digital Concepts... • Answered on Dec 11, 2008
Lost Disk
Through the software disc you can transfer the pictures and edit the pictures . Actually This camera is plug in play device, so when you connect the camera to your computer it will show up as removable disc and this way you transfer the pictures to you computer. So you dont need to have software for this.
And the software is not available online, If still you want the software please call the manufacturer and the # is 877 397 8200
9/28/2008 9:29:45 AM • Digital Concepts... • Answered on Sep 28, 2008
2answers
I need software to download so I can get pictures off my camera
use a memory card reader to bypass camera and offload pics-about 15-20.00 and works great-no power cords or software needed
4/23/2019 4:52:35 AM • Digital Concepts... • Answered on Apr 23, 2019
Digital Concepts 54782/54783 Digital Camera Logo
Popular Tags
28 questions posted
Top Digital Concepts Cameras Experts
Steven Wander
Steven Wander
Steve
Tony Parsons
Tony Parsons
Are you a Digital Concepts Camera Expert? Answer questions, earn points and help others
View Most Popular
  • Digital Concepts Cameras
Most Popular Question
no installation disk camera
  • Cameras
