20 Most Recent Olympus EVOLT E-500 Black Digital Camera Body w/14-45mm & 40-150mm Lenses Questions & Answers
XD card won't "click in" to its slot on an
Check internal alignment card slots.
10/18/2011 8:29:16 PM • Olympus EVOLT... • Answered on Oct 18, 2011
Long exposures
the only way i can think of is by using a remote release which should give you the option to set it for longer.
4/23/2008 5:17:21 PM • Olympus EVOLT... • Answered on Apr 23, 2008
My Olympus C-4000 zoom will not boot to my imac
Did it do it before? It needs Software and Drivers, it may also need Firmware for your iOS version. I am having difficulty bringing up software for it, even where it is linked. https://www.google.com/search?q=olympus+c+4000+imac+software ./..
10/15/2021 9:39:30 PM • Olympus Cameras • Answered on Oct 15, 2021
I had to by a new memory card to my Olympus Camedia C 750. I just found out that the 1GB I bought, will not work. Is tere any way of make a partion to make the camera accept the card?
Is the card you bought compatible with your camera? Older cameras cannot work with newer versions of memory cards. SD, SDHC,SDXC etc. have different form factors and old model cameras are not compatible with newer versions. If the problem is related to the card, you might like to re-format the card from a computer before inserting it in the camera and then format it again from the camera. Check and verify that before you try other solutions.
7/7/2021 3:45:25 AM • Olympus Cameras • Answered on Jul 07, 2021
My Olympus SP-560UZ shows "battery empty" with new standard (non-rechargeable) batteries. Solutio requested please.
go buy a new battery pack we will not do it for you
5/31/2021 9:32:45 AM • Olympus Cameras • Answered on May 31, 2021
Olympus OM-2 spot/program battery problem: the batteries drain in a couple of shots.
I had a similar issue with an Olympus OM4. It went in for repair but was never resolved. The batteries in my OM1-md last forever! I ended up doing the same remove the batteries after use. I can't remember the configuration, but if the LR44 are two and double stacked, you could use the Lithium equivalent. https://www.batteryequivalents.com/ag13-sg13-lr1154-sr44-303-357-a76-lr44-battery-equivalents.html ..
2/1/2021 12:48:55 AM • Olympus Cameras • Answered on Feb 01, 2021
Where I can find Manual for OLYMPUS ACCURA zoom XB70 camera
Olympus would be a possible source.
11/6/2020 7:59:54 AM • Olympus Cameras • Answered on Nov 06, 2020
Can I get rid of 3c81 error code on my Olympus E-1?
Have you tried using Google to find out what the error code actually means ? Very often, the first step in defining and correcting an error is to find out what has caused it.
6/25/2020 10:31:31 AM • Olympus Cameras • Answered on Jun 25, 2020
3answers
Which camera do you recommend - FujiFilm, Olympus or Sony?
I would recommend Sony for a best film or picture.
6/15/2020 8:46:23 PM • Olympus Cameras • Answered on Jun 15, 2020
HI!my device olympus vn8700pc has memory error what should i do to solve this problem?
This does not appear to be a camera
1/27/2020 1:27:18 AM • Olympus Cameras • Answered on Jan 27, 2020
I removed Sand-Disk from my Olympus E-510camera was OFF. Disk did not fit my PC slot, I put the Disk back to camera. However when I switch camera On, the camera showed Disk Full No Pictures.
Is this an SD card or SDHC card ? If so, have you inadvertently set the write-protect switch to 'ON' ? To read it on your computer, you will need to get a USB card reader that will read your particular card, then connect this to your computer, which should treat the card as an extra drive. You say the card has been in use for several years - it may just be corrupted or at the end of its useful life - I should consider replacing it soon.
10/14/2019 2:47:19 PM • Olympus Cameras • Answered on Oct 14, 2019
I have a Olympus sp-560 uz camera . The batterie lid has snapped in half.How can I take the lid off and replace it
For a new battery lid try here https://www.cameraspareparts.co.uk/ Sorry I cant help with removal of the broken part
9/24/2019 7:18:21 PM • Olympus Cameras • Answered on Sep 24, 2019
WHAT OLYMPUS PROCESSOR IS COMPATIBLE WITH MAJ-843 PIGTAIL?
Search on Google will give you several options
9/9/2019 8:00:03 AM • Olympus Cameras • Answered on Sep 09, 2019
Hi do you have a service manual for an Olympus UHI-3 please
Search for it on Google, or contact Olympus direct.
7/22/2019 7:48:31 PM • Olympus Cameras • Answered on Jul 22, 2019
I like update the E-1 Olympus Camera Driver Firmware
Download from Olympus support site
7/17/2019 9:51:11 PM • Olympus Cameras • Answered on Jul 17, 2019
Olympus EVOLT E-500 Black Digital Camera Body w/14-45mm & 40-150mm Lenses Logo
2 questions posted
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Are you an Olympus Camera Expert? Answer questions, earn points and help others
View Most Popular
EVOLT Olympus
  • EVOLT Olympus
Most Popular Question
xd card won 39 t click in its slot
  • Cameras
