20 Most Recent Canon IXUS 960 IS Digital Camera Questions & Answers
http://www.camera-usermanual.com/manuals/canon/Canon_IXUS_960_IS.pdf You need an A/V cable with RCA style connectors at the TV end and a 3 conductor 3.5 or 2.5 mm connector on the camera end. It is shown in the manual.
Canon IXUS 960... • Answered on Sep 10, 2016
remove the memory card. Make sure the little notch on the left side is in the up position. If there is no notch, the camera will handle the card as locked. When all cards you put in the camera act the same (locked) perhaps the switch in the camera is defect. Check if the memory card slot is free of any debris. (use a magnifying glass and a strong light. 25619354-ivbkp2ztpa5subn0yl5eus0z-2-2.png The switch on the card here is in the correct position.
Canon IXUS 960... • Answered on Apr 03, 2015
I have a canon Ixus 960 IS and it will not turn on. I have charged the battery, but it still does nothing. I haven't dropped it and it hasn't been wet. Thankyou for your help
Canon IXUS 960... • Answered on Sep 01, 2014
Check on the display to see if you haven't accidentally set it to macro or manual focus mode. Macro mode is a small flower shaped icon and manual focus is shown as an MF symbol on the display.
Canon IXUS 960... • Answered on Oct 25, 2013
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Canon IXUS 960... • Answered on Oct 04, 2012
As with most electronics the only possible fix is to remove the battery and keep it in a warm environment for a good while to let the electrics dry out. Sadly though the damage is usually done and condensation on the optics probably is not a good thing for taking clear pics.I would likely say you will need to replace the camera sadly :(
Canon IXUS 960... • Answered on Jun 20, 2012
Hello Celia. Try going to the menu and look for the "storage" setting. Check to see if it is set on memory card or internal. Switch the setting to see if you can access the photos. If this doesn't work your 30 photos may be in a folder "type" your Canon cant access. Try moving them to a "Canon" folder that your camera created. Hopr this helps. Dale
Canon IXUS 960... • Answered on Dec 21, 2011
Before doing anything else be sure the battery is actually capable of holding a charge. Worn out batteries charge very quickly in the charger. A healthy battery will take several hours to charge.
When a "charged" worn out battery is put into the camera battery voltage drops instantly when the camera tries to start from it - nothing happens in this case.
Canon IXUS 960... • Answered on Jul 05, 2011
Is the battery powerfull enough? Meaning has enough DC current in it to powerup? There are 2 "ON" buttons one at which the lens comes out, the second to view pictures.
Canon IXUS 960... • Answered on Jun 29, 2011
Hello there,
Have you tried doing a power cycle? By removing the battery for 30 minutes to an hour. This will do a reset of the system.
Let me know how that goes.
Canon IXUS 960... • Answered on Jun 28, 2011
hi,
sorry , i must only say ..... yes
some brand of canon camera has this problem .
and this is actually depending to the chance of buyers which to get the good or bad device .
if you have supported by warranty, i recommended to return it to the relative company.
sorry
gorbesia
Canon IXUS 960... • Answered on Jun 15, 2011
Refer to the "Magnified Close-Up Shooting (Digital Macro)" section of the manual (page 70 in my copy). If you need a manual, you can download one at
http://gdlp01.c-wss.com/gds/4/0900009924/01/PSSD950IS_IXUS960IS_CUG_EN.pdf
Be aware that you will get almost no depth of field at close distances. You also have to be careful about lighting, you don't want to cast a shadow onto the subject. Any camera motion will be magnified, so you might want to use a tripod or some other support. A good library or bookstore will have books with sections on close-up/macro shooting, as well as entire books on the subject.
Canon IXUS 960... • Answered on Jun 10, 2011
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Canon IXUS 960... • Answered on May 23, 2011
Try NOT connecting your camera to your computer.
Canon IXUS 960... • Answered on May 02, 2011
I have a similar problem with my camera which is about 2 or 3 years old. Seems to be a circuit board issue. Costs about €90 to €100.
woofagee
Canon IXUS 960... • Answered on Apr 08, 2011
Issue: How do I reset the camera to its default settings?
Solution: Procedure for resetting the camera to its default settings PowerShot SD960 IS.
Resetting Settings to Their Default Values - PowerShot SD960 IS. 1. Turn on the camera and press the <MENU> button to open the menu. 2. Using the arrowrightbutton.gifbutton, highlight the yellow setup_icon.gif(Set up) tab. sd960menupress.jpg 3. Using the arrowdownbutton.gifbutton, select [Reset All..] and press funcseticon.gif. sd970reset.jpg 4. Select [OK] and press funcseticon.gif. sd970resetall.jpg
  • Settings cannot be reset when the camera is connected to a computer or to a printer.
  • The following cannot be reset:
    • Shooting mode
    • The [Date/Time], [Language], [Video System], and [Time Zone] options in the setup_icon.gif(Set up) menu
    • White balance data recorded with the custom white balance function
    • Colors specified in the [Color Accent] or [Color Swap] modes of My Colors
    • The image registered as [Start-up Image]
Canon IXUS 960... • Answered on Apr 02, 2011
Good day,
This is a common problem and sometimes can be fixed.
Please see details on my tip on how to fix this error here:
http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Let me know if my tip was useful for your problem!
Regards
Canon IXUS 960... • Answered on Nov 29, 2010
Canon IXUS 960 IS Digital Camera Logo
75 questions posted
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
IXUS Canon
  • IXUS Canon
Most Popular Question
need lead show photos from camera tv
  • Cameras
