20 Most Recent Canon Digital Rebel XTi 10.1MP Digital SLR Camera Digital Camera with EF-S 18-55mm f/3.5-5.6 Lens + B Questions & Answers
18-55mm lens lid cover
This lens takes a standard 58mm lens cap. You should be able to buy a replacement cap at just about any camera store. If you want to go online, you'll find a selection here.
12/13/2012 6:27:24 PM • Canon Digital... • Answered on Dec 13, 2012
Need Canon G10 manual + how to load solution Disk 38.1
You can download the user guide and software guides from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=222&modelid=17624
3/6/2012 7:51:28 AM • Canon Digital... • Answered on Mar 06, 2012
Timer
Press the Drive-Mode/Self-Timer button (on the back, near the upper-right corner of the LCD panel, marked with a one-handed clock). Select the one-handed clock, then use left/right to select a timer option. Start the self-timer by pressing the shutter button.
12/16/2010 3:27:34 AM • Canon Digital... • Answered on Dec 16, 2010
Lence Error in A580 Digicam-Canon
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/27/2010 6:40:36 PM • Canon Digital... • Answered on Sep 27, 2010
All the pics from my digital canon xti come out
Remove the lens and fire off a couple of shots while watching the inside of the camera. Does the mirror flip out of the way? Does the shutter open and close?
9/26/2010 1:35:30 AM • Canon Digital... • Answered on Sep 26, 2010
2answers
Err 99
err 99 means there is moisture inside of the camera, probably inside the hot shoe
8/1/2010 10:47:17 PM • Canon Digital... • Answered on Aug 01, 2010
2answers
Is the canon 28-135 with is a good lens
an excellent camera and excelleny lens
8/1/2010 10:41:29 PM • Canon Digital... • Answered on Aug 01, 2010
Image does not appear on LED screen
becouse there is sensor on back cover when put the sreen to your eye display will goes blank.
8/1/2010 10:32:35 PM • Canon Digital... • Answered on Aug 01, 2010
My connon xti 10.1 mp takes many out of focus
I think its reqiure to do the focusing adjustent or you can try to clear all camera setting from menu option four. clear both settings and try to take picture and check out of focus problem.
8/1/2010 5:43:23 PM • Canon Digital... • Answered on Aug 01, 2010
With my Canon EOS digital rebel xti i have the
I think it got exposure problem so need to adjsuted exposure and shutter speed or need to replace either top cover or finder unit i recommend to repaire with canon authorised centrre only.
8/1/2010 5:37:45 PM • Canon Digital... • Answered on Aug 01, 2010
Compatable tripod for Cannon XL H1 camcorder
er~ maybe you can visit
http://www.linkdelight.com/index.php/Support-Gears/View-all-products.html
hope it can give your some help
4/15/2010 8:19:14 AM • Canon Digital... • Answered on Apr 15, 2010
How do you take inside photos with out a flash and
take the unit out into as bright a daylight as you can - the bottom line is you need light, hence flash or you need to take a longer exposure than you can hold - hence tripod - not having either of these means you need to get light into the speaker box You could try household lamps and point a few at the speaker cabinet - remember to set the white balance to tungsten also a camera lens with a good aperature F1.8 - Depth of field (focus) will not be very much at that aperture setting though
4/11/2010 1:44:29 PM • Canon Digital... • Answered on Apr 11, 2010
Viewscreen stops working with Ikelite UW housing for my XTi
It is obvious that light is not reaching the image sensor. You will have to m-ess around with a lot of settings to be able to get an image. So instead of typing everything, I am linking you to a page that explains these settings in detail
http://digitaluwphotography.com/settings.html
Hope this helps,
Sai.
1/25/2010 3:41:54 AM • Canon Digital... • Answered on Jan 25, 2010
How to attach wide angle lens to telephoto
I don't understand your question...a wide angle and a telephoto are two different lenses.
11/12/2009 11:12:57 PM • Canon Digital... • Answered on Nov 12, 2009
2answers
How can i print date
you can do that if you're doing direct printing (camera to printer) using the caera transfer settings, or if you want to save them to your omputer, you need to download the photos using the EOS utility (comes with the camera) and add the [date & time] stamp from the software settings
9/21/2009 7:38:56 PM • Canon Digital... • Answered on Sep 21, 2009
How I change yhe ISO on a canon XTI
from it menu ...there are options for other choices..
8/3/2009 3:59:38 AM • Canon Digital... • Answered on Aug 03, 2009
Memory card will not lock into down position. will just bounce back up
It seems that the CF reader mechanical assembly part is loose or it has out of place an internal part.
It may be caused by excessive force in pushing/pulling a CF memory card, or due to a manufacturing issueof the camera.
The solution is to open the camera, and check what is causing the problem and fix it.
If it's under warranty, I do recommend you to return it. If not, then you will need to pay for its repair, or do it yourself if you have experience, skills and patience in fixing electronic devices.
Such repair will require some philips screwdrivers, a soldering iron, soldering wire, and a st of tweezers.
There are in internet some guides to open and disassembly Canon XT 350D or Rebel 300d cameras. The disassembly process with the XTi 400D is very similar. You can Google fr such guidelines.
Best regards,
7/23/2009 11:21:39 PM • Canon Digital... • Answered on Jul 23, 2009
Canon rebel xti digital camera mem. card will not lock into place
It seems that the CF reader mechanical assembly part has loose or out of place an internal part.
Best regards,
7/23/2009 3:31:06 AM • Canon Digital... • Answered on Jul 23, 2009
Canon Digital Rebel XTi 10.1MP Digital SLR Camera Digital Camera with EF-S 18-55mm f/3.5-5.6 Lens + B Logo
Popular Tags
32 questions posted
Top Canon Cameras Experts
old marine
old marine
David Shaub
shadow
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Rebel Canon
  • Rebel Canon
Most Popular Question
canon 28 135 good lens
  • Cameras
