20 Most Recent Braun Tassimo TA1200 Espresso Machine Questions & Answers
Several possibilities: (1) No water in tank.
(2) Tank not inserted properly. Try removing tank and then replacing it, making sure that the hook-tab at the back of the tassimo body engages the matching slot at the front of the tank.
(3) Tank not seated properly. Try pressing down on the tank and twisting left or right. If this stops the blinking and allows your drink to brew, at least you know where the problem is. If you have to do this all the time, consider exchanging the unit.
(4) The lights will all also blink if there is residue (coffee, milk, etc) on the bar code reader window. The residue is usually plainly visible. The bar code reader window is a horizontal rectangel directly under where the bar code of the T-Disc sits in the Tassimo. To fix this, just wipe the window clean (no need to scrub), close the lid again and check for blinking.
Braun Tassimo... | Answered on Jun 24, 2017
I ran into the same problem myself. One possibility is this: Follow this sequence: 1) With the top up and the disk NOT engaged, turn the main power on. 2) Put the disk in and lock the top down. At this time, the cup logo shouls flash once and stay on. 3) Push the large round button once and the cup logo will flash and the brewing should start.
I had a few things out of sequence at first and it was frustrating me as well. I hope this helps!!
Braun Tassimo... | Answered on Oct 31, 2013
Buzzing means that the motor is energized, but something is jamming the grinder gears. The could be something metal, or it could be that the bearings are dry and seized. You need to strip it to find out.
https://www.google.com/search?q=Braun+KSM2+grinder
Braun Coffee... | Answered on Jan 27, 2020
cont_babe
  • 4 Answers
SOURCE:Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
Braun Coffee... | Answered on Feb 12, 2019
Google (braun)(4045)(manual) without parens.
Braun Coffee... | Answered on Oct 28, 2018
Braun Tassimo TA1200 Espresso Machine Logo
17 questions posted
Top Braun Coffee Makers & Espresso Machines Experts
Charles Tidwell
ThaMp3Doctor
ThaMp3Doctor
Are you a Braun Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Braun Coffee Makers & Espresso...
  • Braun Coffee Makers & Espresso...
Most Popular Question
all lights flashing braun tassimo
  • Coffee Makers & Espresso Machines
