20 Most Recent
Cuisinart EM-200 Espresso Machine Questions & Answers
My cuisinart EM-200 doesn't seem to be taking in any water. It turns on, goes through the initial cycles. Then beeps and lights flash indicating there is no water in the resevoir. Although ther
Hi.... The problem is the flow sensor under the EM-200. There are three special screws. Inside there is this flow sensor. It´s a Hall effect transitor (w5029) but the problem is the small magnet in the small turbine inside the sensor. Open it, take the small magnet away, make a hole throught it from side to side and then glue the small magnet in the top side, closer to the sensor. It will work again. Brown wire = GND - White wire = 5Vdc - Yellow wire = pulse...After 1 year and 3 months, the problem appeared again. The same flow sensor. The small magnet was completly rusty. I had to change it with a new one. The problem is solved. You can also buy a new flow sensor at Aliexpress. Go there and look for: " Water Flow Sensor 0.3-6L/min Switch Meter Flowmeter Counter Sensor Water Control 1/4" 1.75MPa DIY Kit" Good luck !!
Hi there. all of a
I don't have a solution, but I have the EXACT SAME PROBLEM!!!! Just started this morning and I am not a happy camper....
Relieve preassure
the filter might be clogged..let it soak in in cup of water foe a while then rinse upside down. this worked for me.
