20 Most Recent Mixcraft Acoustica 6 6 Questions & Answers
mixcraft 6 register code
Mixcraft... | Answered on Oct 26, 2019
Is this one of the units that has a ribbon cable ( looks alot like an IDE hard drive cable) that connects all the components together? It also has a squre plastic fan that protrudes slightly from the rear (by about a 16th of an inch)? If so, it's the power module which consists of 2 boards (along the fan housing). You can probably find replacements for about $70, but I wouldn't bother. They quit making new replacements several years ago and any board you get now is just a pull from old stck units.... and they fail about 2 minutes after you put them in. Pioneer knows this but still sells the defective parts.
Audio Players &... | Answered 15 hours ago
you need to get into the box, and sort all 100 of the cd's out yes all of them..
to this i mean make sure they are in there tray's properly,second make sure the tray's are not "racked",ie that they have not slid out of there small holder's..
now once u have the mean's open the juke box..
find the black switch, pull it out to engage service mode<,
now u go to work on the cd's, then you will hit "h" 0-0 "h"
this should clear your error 73 code ,as long as all the cd's are in there proper place's
press switch back in, you are then back to normal play
at the point of closing the door you might need to power cycle the juke box
Audio Players &... | Answered 2 days ago
Connect the AUDIO OUT ports on your DVD player to the audio in ports on your TV with the regular or standard audio cables (red and white jacks). Connect the AUDIO OUT ports on your TV to your speakers using a standard audio cable, or a digital audio Optical cable.
Audio Players &... | Answered on Aug 09, 2020
200 watts is the output, home use or commercial? not a good amp to run at its max as it has a low reserve headroom. for home use 100 watts rms is more than enough.
It is radio controlled and sets itself.
Audio Players &... | Answered on Aug 04, 2020
This is a very common issue. Unplug the mini power jack the thing with the cord. Look inside the chargers hole on the jam box and then take a knife to gently bend the tab back towards the middle or even lower. Be careful when you are re plugging into the power into the socket. The socket tab and the mini plug must meet .
Audio Players &... | Answered on Aug 03, 2020
The AUX connection is what the Line In connection used to be called and generally has a medium impedance and a sensitivity of upwards of 800 mv, often 1 to 1.5 volts, being the typical output of a tuner or tape deck.
Details of this is usually found in the user manual - good matching is repaid in better quality sound and reduced interference.
Audio Players &... | Answered on Aug 02, 2020
Press the buttons of your mystery appliance in the correct order.
OR
You could Google
make model manual
Audio Players &... | Answered on Aug 01, 2020
The DVD and *and* the DVD player both have a region code embedded in each. A map of the regions used appears below:
Regions 0, 7, 8 & 9 do not appear as they represent "No Region Coding" "Unused" "Cruise Lines" and "Region Free" respectively.
A DVD player will only play a matching region code DVD, or the player OR DVD have one (or more) 0, 7, 8, or 9 region codes imbedded. You'll not be able to change the DVD code, but you *might* be able to change the region code of your player. Computer DVD players can sometimes be flashed to a new region more readily than the entertainment system DVD players, but it relies solely on the manufacturer and model of the player. Some require file be downloaded and run, while others require a DVD or CD be created and played with a specific file saved on it. Here's a link to results that discuss how to change the region code for DVD players. You'll need to know at the very least the manufacturer and model number of you player to begin.
I hope this helps and good luck! If you found this helpful, please rate my reply 4 "thumbs up". Thanks!
Audio Players &... | Answered on Jul 30, 2020
Press and hold the MFB buttons for about 5 seconds to turn them off. When both earbuds are paired with your cellphone, press and hold the MFB button on either left or right earbud, the other earbuds should turn off at then at the same time.
Audio Players &... | Answered on Jul 29, 2020
The speakers may be burned out.
Audio Players &... | Answered on Jul 27, 2020
The manual has the complete process how to set time.
Audio Players &... | Answered on Jul 22, 2020
A faulty volume potentiometer? Some internal cross-talk? Free wires induction because they are too close, inside? It sounds possible to me and a minor problem. Don't worry too much.
Mixcraft Acoustica 6 6 Logo
11 questions posted
Top Mixcraft Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Mixcraft Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Mixcraft Audio Players & Recorders
Most Popular Question
mixcraft 6 registration code
  • Audio Players & Recorders
