20 Most Recent
Minolta FAX2900 Plain Paper Laser Questions & Answers
Hi i have minolta Dialta 520 Photostate machine
The error code C-1028 on a Minolta Dialta 520 photostat machine typically indicates a problem with the paper feed system.
Based on your description, it seems that you have already replaced the PWB-B Board and checked all jacks, but the problem persists. In this case, there could be a few other potential causes of the error.
- Paper feed motor
- Main control board
- Gears or other parts in the paper feed system
- Paper feed sensor
Regarding the Bet Pin, it could be the name of a specific pin on the PWB-B board or in the paper feed system, but without more information about the specific location or context it is hard to say exactly what it is referring to.
It is recommended to consult the service manual of the machine, or contact the manufacturer or a professional technician for further assistance. They will be able to diagnose the issue and provide the necessary steps to fix it.
Minolta di 620. What causes error C-13F0?
Open the front door of the copier, copier must be on. Look to your upper left, you should see a small cover with a screw remove and the cover. Inside you will see a two small buttons, the left one, press it that should reset the copier. Then power off thw machine and wait 10 seconds and power it on. AGAIN if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!!
We have an older minolta bizhub 250 and the touch screen is working but now where you touch. can this be fixed or do we need to find a replacement part
Sir/Mam,
On the right side of the machine just below the scanner section (The part with the big glass) is a cover next to where you connect the Ethernet cable. Remove the cover, with the machine on use a small screw driver and gently depress the small black switch. The machine is going to go thru some screens watch the left side of screen in the middle you will see a "." when that is displayed press 3. If required Enter the 8-digit service code and touch [END]. (Default value: 00000000)
Select Touch panel adjustment Touch the four + in the four corners Upper left, Upper Right, lower left, lower right. Power off machine wait 10 seconds power on.
Minolta EP 3170 copier will not switch on
Ensure the power plug is properly installed not lose. That is a serious legacy (Super Very Old) machine. Unplug machine and remove rear covers. Look for fuse or circuit breaker. loose connections. if notice nothing plug in and using a volt meter test for voltages on any red wires connection. Black and white wires are 120 VAC be care full green ground
The machine not working sowing please wait only
Trennen Sie beim Start externe Laufwerke, Peripherieger?te usw., warten Sie einige Minuten und schalten Sie Ihr System mit Kamagrabest ein. Jetzt fahren Sie Ihren Computer dreimal hintereinander kaum herunter und dann wieder ein. Befolgen Sie diese Schritte Kamagra Bestellen https://kamagrabest.net/, indem Sie zuerst den Computer einschalten und dann direkt den Netzschalter erneut dr?cken, aber diesmal gedr?ckt halten.
Hi, can some one help me; i've error code 3b02 displayed in minolta c452
Sir/Mam,
Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit or a High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Konika minolta c554e error code C-3102. HOW DO YOU FIX THIS.
1 Check the fusing unit for proper installation and correct as necessary.
2 Check the connector between M3-PRCB CN2 for proper connection and correct as necessary.
3 Check the connector of M3 for proper drive coupling and correct as necessary.
4 PS37 I/O check, sensor check.
5 M3 operation check PRCB CN2-9 (REM) PRCB CN2-12 (LOCK) bizhub C554 22-J bizhub C454 21-J.
6. Replace M3.
7. Replace the fusing unit.
8. Replace PRCB.
