20 Most Recent Sony NWZ-A816 Digital Media Player Questions & Answers
I had the same problem my mp3 would not charge.To fix connect the mp3 to your computer with the usb cable, go to Device manger open up portable devices you should see a small yellow triangle (this is telling you some thing is wrong) right click over walkman and choose up date driver .windows will use hardware wizard on the net to fix the driver.This worked for me i hope it fixes your problem
Sony NWZ-A816... • Answered on Mar 30, 2014
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer.You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Sony NWZ-A816... • Answered on Feb 27, 2012
try this :
This works on most mini electronic devices like cellular phones and degital cameras etc .
it sounds crazy .
Remove the back (or Cover ) of the phone( or Camera ), battery, and SIM if your phone ( or Device ) uses one , DIRECTLY
Then, with a q-tip (or something similar), dab the connection points (shiny, goldish) on the battery, SIM, and phone. This should aid in drying.
Finally, place all contents in a bag of uncooked rice (separately, do not put back together just yet). it sounds crazy , but it draws the moisture out.
It normally is working after just 7-8 hours, but I would wait 12 hours or even 24 hours before attempting to use (just to be sure).
beware the water damage, despite being dry now, will void any warranties. Also, the phone's hardware is now weakened and if you drop it, the green mother board and circuitry could shatter - so be more careful.
This does work on electronic devices aside from phones as well. Simply tailor it to your device. If you do not have a SIM (Verizon phones, cameras, all others), remove only the battery. If you have an iPhone/iPod or GPS and cannot remove the battery, simply make sure it is all the way off, then put it in the rice bag. All electronic devices react the same to the rice trick.
related link is here : http://www.youtube.com/watch?v=0-Otjgd48nY
rate if useful please !
Sony NWZ-A816... • Answered on Jan 17, 2010
HI
THE SOFTWARE OF WALKMAN IS GET CORRUPTED SO ITS BETTER TO LOG ON TO THE OFFICIAL SITE OF SONY AND THERE THE SOFTWARE IS AVAILE FOR YOU.
THANK YOU.
Sony NWZ-A816... • Answered on Sep 10, 2009
Purchase a usb power plug to plug your device into the wall if it charges then your computer just needs to re install the device driver
Sony NWZ-A816... • Answered on Aug 29, 2009
Try a different USB cable instead. Most likely a pin in the USB cable your are using is faulty and because of that your computer can't detect your player as the pin required for your computer to detect it is faulty. You can take a look at http://mympx.org for other users who have similar problems as well.
Sony NWZ-A816... • Answered on Jul 14, 2009
You may have a defective MP3 player. I had one and had to send it back (it wouldn't show up on my laptop, and it manifested a graphical problem). If the company you bought it from is reputable they should refund you. ALWAYS be sure to buy expensive items like these ONLY from reliable sellers, even if they're a little more expensive than others!
Sony NWZ-A816... • Answered on Jun 04, 2009
u need to upgare the firmware of ur unit to perform that tell me what is ur os okay and i will help u.
Sony NWZ-A816... • Answered on May 07, 2009
does the pc recognise the device when you connect it? if so you should be able to access the drive which contains the mp4 folders. very rare that they will be kept on the top level of the drive. navigate to the folder on the device which would normally contain your mp4 files and drag files from your storage backup folder direct to the device. checking that you have the files in the correct format ie: .mp4 you should find they play fine. try to avoid wherever possible using the acctual software which controls your music device as they are prone to complications.
Sony NWZ-A816... • Answered on Mar 04, 2009
i have the same problem help anyone
Sony NWZ-A816... • Answered on Oct 24, 2008
I have the nwz-a816 and if have had this issue a couple of times... It seems to give me that message on songs I have downloaded from Napster... I just connected it to the computer that the Napster application is on and it corrects this problem... Hope this helps...
Sony NWZ-A816... • Answered on Jul 16, 2008
it's the 4GB NWZ-A816PNK Walkman version?
connect usb to your computer
wait for the connect sound
open my computer
look for removeable drive
right click on it and explore
go to music folder
open your library
drag w/e songs u want into the music folder
dc, turn on. browse and play. hope this helps.
Sony NWZ-A816... • Answered on Feb 24, 2008
I am facing the same problem I have tried cold reset but no luck can any body please guide me abt the factory reset or the exact solution of this problem. Display flashes but no any button works.
Sony Audio... • Answered 15 hours ago
Sony NWZ-A816 Digital Media Player Logo
27 questions posted
Top Sony Audio Players & Recorders Experts
aliasger yq
Alvin Barnabas
Alvin Barnabas
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony nwz a816 options all white barred
  • Audio Players & Recorders
