20 Most Recent Sceptre x22wg Gamer Monitor Questions & Answers
I have two of the X22WG monitors, both dead. The power supply in this model is apperently plauged with a common error. The problem is close to the +5V and +12V output connector (Far right corner, with power plug against you). Two out of the four small caps are blown. Replace those, and it should be fine. C551 and C552.
Sceptre x22wg... • Answered on Jul 29, 2012
you need to check if your capacitors are blown, if they are, you can replace them...it's a very economical way of fixing it. This is a common problem of Sceptre x22wg-gamer.
Sceptre x22wg... • Answered on Jan 24, 2012
Make sure windows finds your monitor in your OS(operating system) Start<My Computer< right click on my computer and click properties< device manager < goto Monitors and see if windows finds it. If you have a graphics card, make sure the card has the latest driver installed from the webite.
www.nvidia.com www.ati.com
Sceptre x22wg... • Answered on Jun 05, 2011
Hi ,
Here are steps that may help you fixing the problem. You should prepare tools and multimeter.
I'm assuming that your unit is dead set without an standby LED light and your outlet is live.1.Power cord - check the cord it might be opened (no continuity).This is due to frequent bending,pulling. 2. Power switch - check for dry joints, open contact. 3.Check the internal fuse- sometimes the fuse fail because of the power surge, replacing with new one will cure the problem, If this is the case I've advice you to use surge protector/AVR (Automatic Voltage Regulator). However if the fuse blew again this is an indication that you have a shorted parts on the power supply, you may visit the linkhttp://www.fixya.com/support/r8053361-fuse_keeps_blowing for more info. If no reaction and still the unit didn't power up then you have an open parts on the power supply.
4.If you see that the fuse is intact on the board, don't attempt to touch anything because there somefatal components stored electricity enough to hurt you with a simple mistake only.
The next steps should be done by an expert or qualified technician because isolating the problem on the power supply is technical and complicated.
Also check if your unit is under warranty before opening the back panel, it will void the warranty. Avail it because the manufacturer of your unit will fix it for free or a little charge only.
Hope it may help you.
Thanks for using fixya.
Sceptre x22wg... • Answered on Feb 11, 2011
Colour changes like this are either due to a failing graphics card, failing monitor or bad connection from the computer to the monitor.. with this monitor, I'd have it checked by a tv repairman
Sceptre x22wg... • Answered on Jan 18, 2011
Maybe Your Browser Has An Auto Temp-Cache Clear I Would Right Click On The Link Save It To My Documents Or Your Desktop Then Try Opening It From There.
Sceptre x22wg... • Answered on Jun 07, 2010
I'm having the same problem. Had the monitor for almost 2 years and everything was working fine until this week. The blue light would blink, then after an unpredictable period of time, the monitor would turn on. Seems like it needs to warm up or something. I suspect it has something to do with the capacitors not charging inside. Somewhat disappointed with Sceptre. I suppose I should be thankful that I got 2 years out of it.
Sceptre x22wg... • Answered on Apr 01, 2010
I am sure that this is not a plug and play monitor. You need to download an install the drivers for this monitor inorder for your operating system to understand the monitor and send signals to it.
I could have helped you in having the correct drivers downloaded if the model number was mentioned. Please check the net you would find the required drivers for the windows you are working with.
Thanks
The only tools you'll need to open up the X22's case are your hands and something like a plastic putty knife. First use your hands to pry the face plate away from the housing along one of the four sides, that is, working from the middle where resistance is lowest. After you create a gap, insert the the edge of the putty knife and forcibly slide it toward one of the corners. This will separate that portion of the face plate. Do the same for the second corner. Now one side is free. Do the same for the other three sides. After you remove the face plate you'll see 4 screws that pin the lcd panel to the housing. After you remove them, be careful not to allow too much force to pull on the cable assembly that connects the panel to the mobo. Just reach in and squeeze the little metal clamps that fasten the connector to the panel. Do not try to disconnect it from the mobo from this angle. Disconnect it from the panel. Good luck.
Tom Raywood
Sceptre x22wg... • Answered on Feb 16, 2010
Your monitor has 3 or 4 blown caps right next to the power plug. They are CapXon 470uf25v. Just open the back and remove the power board, desolder, and replace the 3 or 4 caps put it back together and it should go back to working. This a typical problem with the Sceptre gamer, HP1706, and the HP1903. And guess what they all have the same caps blown in almost the same place.NOTE: When seperating the case the power led is glued to the front frame. Take your time if you rush you will break a cable wire or plug.
Sceptre x22wg... • Answered on Jan 11, 2010
Check the monitor's internal setup program.
Some monitors have a preset for idle timeout. Of course, as long as you're using the computer, this feature should not be activated and the timer should start over each time you perform any activity on the monitor.
If this is the problem, it should be a simple matter to turn off the time-out feature or set the time to a very high number so that it seldom (if ever) takes effect.
Sceptre x22wg... • Answered on Jan 01, 2010
hey
usually this happens due to static try to power cycle the monitor by disconnecting all the cables from the monitors
then connect teh cables back one by one
and see if it works and if not yes get teh monitor replaced
Sceptre x22wg... • Answered on Sep 18, 2009
warcryofjuda, One of the guys that I work with brought in a small screen Sceptre DTV/DVI/VGA +audio unit. and it also has a optional TV/tuner module. mod S1701DTV with side mounted speakers. The viewable screen size is 14"w x 8.75"h . Oh! First things first! Turn it OFF and leave it off. Disconnect it and put it in a safe place for now. IT'S BROKE!! It will not work today, and it will not work tomorrow or the next day. Got that? Ok! Now I want to know if you would like to work together with me and explore both of these monitors and possibly come up with a fix for them? Please get back to me via my email with what ever approach you feel is best for you. We have already opened up our unit and I will try to attach some pic's for you to compare your unit with. I'm louie12fix on fixya or [email protected]
Bye for now.
Sceptre x22wg... • Answered on Jul 20, 2009
unfortunately. This is a classic symptom of a faulty inverter board. I would suggest looking on ebay to see is there is a cheap replacement. Purchasing a new one is usually not economical these days.
Sceptre x22wg... • Answered on Jul 11, 2009
Sceptre x22wg Gamer Monitor Logo
27 questions posted
Top Sceptre Computers & Internet Experts
Michael Thomas
Michael Thomas
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Sceptre Computers & Internet
Most Popular Question
openin case sceptre monitor try fix no
  • Computers & Internet
