20 Most Recent HP w17e Monitor Questions & Answers
How do I open a w17e monitor
As with all monitors which are flat screen types, you need a couple of tools for the job. First a Phillips head screw driver to remove the screws from the mounting pillar and any case screws. Second you need something like a small putty knife (plastic if you can find one (cheapies at Lowes or Home Depot for example). The case is opened by sliding the putty knife between the front and rear case halves angling from the rear to the front to gently rock the case latches loose on the inside where you can not see them, working your way along the case sides, either clockwise or counterclockwise around the screen perimeter.. just make your way around, one latch at a time.. Also, do not pull the halves apart as you make you way or you risk either rounding the latches off or breaking them all-together while disconnecting them. Be careful around the bottom front since this is where the control keys are normally located for the monitor (on-off-menu-etc.). The controls should come off with the front half, and the cables are usually pretty tiny and fragile - FYI. Once you get inside, you will see the power supply mounted to the back of the screen assembly. At this point it you should be back in normal looking territory once again to begin whatever repair you are after now. To put back together, you simply "snap" the two halves back together (you will hear the obvious "clicks" which indicate the latches are snapped into place once again (going together is much easier than taking apart, so be sure all is working before putting back together.. just sayin'). We professionals use a glorified putty knife affectionately known as a "MAC-cracker", which was sent out to service people working on the old Apple systems which were snapped together like this a long time ago.
12/1/2014 1:20:19 AM • HP w17e Monitor • Answered on Dec 01, 2014
manual
0answers
My speakers crackle when volume on loud
It's possible that the speaker could damaged or you may have a shortage
5/11/2012 11:45:59 PM • HP w17e Monitor • Answered on May 11, 2012
How to restore default setting to display i am using Hp w17e
On your main screen do a right mouse click and in the drop down menu, select properties or screen resolution. That should bring up your screen settings, normally they show which setting is the recommended setting.
12/31/2011 3:33:41 PM • HP w17e Monitor • Answered on Dec 31, 2011
0answers
0answers
Thin black horizontal lines across
Hi there.
I suggest you see my tip on how to fix the lines on your monitor. The fix for horizontal lines is the same for vertical lines. You can read my tip here: http://www.fixya.com/support/r9352105-fix_colored_vertical_lines_lcd_display
Slasher_X
7/21/2011 4:17:00 PM • HP w17e Monitor • Answered on Jul 21, 2011
I have a attention input
This is most likely because your computer is trying to display a screen resolution higher then tht monitor can support. Turn your PC on, and press F8 until you see a black and white menu. Select safe mode. Run safe mode and when windows loads, goto your control panel. Select Display and navigate to the resolution / settings tab. The screen resolution should be set to 1440 x 900 for this monitor to display video correctly.
If you need more detailed information on where to find the display resolution settings in windows I will need the name of the OS you are running... XP, Vista, Win 7 etc..
Regards, Chris
7/1/2011 2:15:03 AM • HP w17e Monitor • Answered on Jul 01, 2011
The speakers on the front
Check the audio jack plug from monitor to cpu if connected correctly. The audio jack plug should be connected to the sound card for audio out. You can also check if the volume in the monitor is adjusted or mute
6/27/2011 9:05:25 PM • HP w17e Monitor • Answered on Jun 27, 2011
There is no sound coming
Yes, you will need a seperate wire that goes from the input in the monitor to the sound adapter on your computer. The cable plugs should look something like this:
6/8/2011 9:48:42 PM • HP w17e Monitor • Answered on Jun 08, 2011
How do I navigate in
There should be a couple of other buttons on the monitor possibly with a picture of an arrow visibly close to them. These buttons should provide navigation while in the menu. They made provide a different function while outside of the menu. For example a brightness button might increase the brightness of the screen but when in the main menu it might move up in the menu. The button has more then one function.
5/12/2011 4:10:16 PM • HP w17e Monitor • Answered on May 12, 2011
HP w17e Monitor Logo
81 questions posted
Top HP Computers & Internet Experts
Marvin
Marvin
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • HP Computers & Internet
Most Popular Question
hp w17e not powering up
  • Computers & Internet
