Disconnect everything from the monitor including power. wait a minute. Connect only the power. If it still does not power up the monitor power supply is dead.
Not much to do but replace the monitor.
That is a very common symptom of a failure in the power supply board. This model uses the same power supply board that the VA1930 model uses. Here is a link to repair information that shows what capacitors to replace on the power board to repair it.http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=168I hope this helps,BuddyMc
Check DC filter caps for leaking/bulging top in the power supply. Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums Post back what you see inside so we can guide you further and it will help out other people in the future also. http://en.wikipedia.org/wiki/Capacitor_plague http://www.badcaps.net
FIRST WE DO NORMAL AND LATER TRUE CAUSE.
gee that is normal on all monitors and by Energy Star laws too.
the monitor if the PC is dead or in speed mode, shuts of in 15 to 90 seconds, all do, every one. the monitor has self sleep, all do. everyone ever made did. even back to CRT days.
and the OSD button goes dead after. that. too. fooling the untrained.
here is the first tests, NO PC connected at all
power on see power light glow correct color
then see Viewsonic splash screen push the menu button now. quickly, if button dead hold it for 10 to 15 second to reverse the button lock now, see OSD works.
if you test the monitor on a good PC not in sleep mode the but working PC, your monitor is ok.
this monitor is very very old, 2004?
it has CCFL back lamps not LED<
and all fully used CCFL lamps are now no good, used 8yrs a day at 5years are no good. that is why we use LED back lamps now.
this is what they do: all do , used fully.
1: goEs dead forever, (vast did)
2: INTERMITTANT . (BINGO YOU ) OR INVERTER DEAD.
3: DIM BULBS (like me. lol)
4 TURN YELLOW FOR WHITE screens.
5: STROBEs. (FLASHes)
AND A VERY EXPENSIVE SURE, THAT. AND LABOR.
power on and power on led glows normal , not yellow or flash.
then this happens splash. attached, 2014 made.
then that tells you screen is NOT DEAD is it? now? here?
(PC is dead or missing)
NO connections on 1 or more inputs.
NO sync
no signal
OUT OF RANGE
and goes black screen NEXT,. if all that fails power supply is bad.
if all that works the menu button works for 15 seconds turned on with no PC, and also works on all PCs if connected to one that are all good and not sleeping. test the monitor on 2 PCs if confused.
that means just what it tells you
the PC is dead, PC video dead or video cable unplugged , dog chewed it , pins bent or plugged in wrong on 1 or both ends.
or monitor not selected to the correct input port (OSD)
PC power lamp glowing not amber or blinkikng
PC fans spin , PSU fan and CPU both
if PC has GPU card in PCI-express slot it must be use those ports only for video.
PC not beeping
PC not texting errors post.
PC not blinking codes on LED or caps lock or POST ERRORS !
NO PC told
PC dead.
PC not stuck in sleep mode , hold PC power button for 10 full seconds to end it, (cold boot that is)
test monitor on end good PC? yet?
WHY DOES THIS SEARCH SHOW.The Viewsonic VSR220 no such thing.?Turn the monitor around, 180 and see the TAG sticker with real model toldno PC told , what PC is this?this ? VSD (D key is next to R) so huge typo"?https://www.viewsonic.com/eu/products/lcd/VSD220yes that is a PC (android)but can do monitor like duty. too.it needs service.if screen is dead, it has power problemsas the screen must at least show a viewsonic splash as power is turned on.try it on a 2nd room AC power jack yet:?if in warranty take it back to the storeor call viewsonic for help.the android PC can use an HDMI cable to a PC and works as a monitor.too.the manual states"4.5 Connecting to HDMI-compliant Devices via MicroHDMI InputHDMI (High-Definition Multimedia Interface) is a compact audio/videointerface for transferring uncompressed digital audio/video data. You canobtain the best user experience for video playback and gaming via HDMI.VSD220 is equiped with a micro HDMI input for connection to an externalHDMI-compliant device. You can connect your PC, notebook, Blu-ray playeror any other HDMI-compliant device to VSD220 for high-definition videodisplay."
Hello Edelberto, this monitor does not disarm by the back to disarm the monitor, you have to remove, with great care, the front frame and there you will see the obstacles you have to remove the panel assembly and the platelets
I hope you can disarm it, comment the results
Greetings Franco Dosil
Hola Edelberto,este monitor no de desarma por la parte posterior para desarmar el monitor, tienes que retirar, con mucho cuidado, el marco frontal y ahi veras las trabas que tiene para sacar el conjunto del panel y las plaquetas
Espero que puedas desarmarlo, comenta los resultados
Saludos Franco Dosil
http://www.viewsonicglobal.com/public/products_download/36/29622.pdfhttp://www.viewsonicglobal.com/public/products_download/36/29639.pdf
The problem is seems to be in power supply section. it may be need to repair by electronic technician, after using any monitor 5 to10 years there may be power section or lcd panel may be damage.
First, I'm not a Viewsonic representative.
* Check your warranty. call for support.
*** Following for information only.***
* No signal means no usable signal for a specific input on the TV or monitor.
* If it's just a monitor and not a multi-function TV that also has a Computer to video input then you need to check the device that's hooked up to the monitor as single function monitor's usually only have one input.
* If this is a TV then you need to go to the TV menu and check the "Input Source" to make sure it's on the input plug your using. (I'm using HDMi-2 on my laptop to TV)
* If it's not on the correct input then there will be a different signal (DVD, VCR, etc.) or none at all (No Signal) if those units are turned off.
* Unplug all devices (to reset) and count to 10. Power up and perform set up to your existing configuration.
* Note; as of Jan 2018 most cable TV are not broadcasting in analog (chan 3) and must use a digital tuner to get signal. Some cable Co. provide converters (for a fee?)
* Check with your service provider for more information.
Aloha, ukeboy57
PS, If you do have a damaged input (or feed) then check your video device for alternative outputs; IE: RCA Vid-Right-Left audio, HDMI, Split video (Y-G-B), VGA, S-plug, etc.
