20 Most Recent Gateway GT5432 Refurbished AMD Desktop Computer - AMD Athlon 64 X2 5000+ 2.6GHz , 1GB DDR... Questions & Answers
one way would be to download and install latest device drivers from the net. it should help.. if you are using win XP, there is likely a BIOS or Windows configuration problem. On some computers there is a configuration option in the BIOS that asks whether an IRQ should be assigned to USB. Although the option's actual wording varies among BIOS manufacturers, you must enable this option by setting it to either On or Yes (depending on your BIOS manufacturer and BIOS version). Otherwise no USB devices will work on XP. A problem with Windows XP’s USB Controller configuration can also prevent any USB devices from working. To determine whether the USB controllers are working properly, open Device Manager and expand the Universal Serial Bus Controllers node. Beneath this node, you should see a USB Universal Host Controller and a USB Root Hub. Depending on your PC, there will either be a USB Universal Host Controller and a USB Root Hub listed for each of your computer’s USB ports or a USB Universal Host Controller and USB Root Hub for multiple ports
Gateway GT5432... • Answered on Dec 10, 2013
Hi bridges_sher
You will find it here : http://www.geeks.com/products_sc.asp?cat=372
or in any large computer store .
Best regards , fanaudi .
Gateway GT5432... • Answered on Aug 26, 2011
Gateway Support > GT5432 desktop computer > Components >
Motherboards > 4006157R - ECS MCP61- P AMD Motherboard >
Product View > T - Front Panel Connector,
http://support.gateway.com/s/MOTHERBD/Shared/4006157R/4006157Rmvr22.shtml
The Power On switch connects to Pins 6 and 8.
Should you not understand the chart, or need additional info regarding this, just post in a Comment.
JCV
Gateway GT5432... • Answered on Jul 17, 2010
please see this:
http://www.computerhope.com/beep.htm
according to the above link, if there are 3 long beeps then it is a keyboard error. listen carefully and then choose your error from the list
Gateway GT5432... • Answered on Jan 24, 2010
It sounds like your laptop BUS (usb power) does not have enough power to power the interface between the two. I had a couple of devices that did that. You may have to buy a SELF powered USB HUB in order to make them connect. The self powered usb will get it's power from and A/C wall outlet and not the laptop. You will connect you device to hub and hub to laptop.
Gateway GT5432... • Answered on Sep 19, 2009
There should be a lil whole beneath the dvd drive where you can stick the end of a paper clip or earing to eject the disc manually.
Gateway GT5432... • Answered on Jul 30, 2009
don't be afraid there are softwares that will restore files even if you format or partitioned your hard drive. start looking recovery programs.
I hope this will help
Gateway GT5432... • Answered on Sep 19, 2008
To get rid of downloads easily with out doing an overhaul on the computer, simply go to the "Control Panel" of the computer and click "Add/Remove Programs"
Gateway GT5432... • Answered on Jul 10, 2008
It depends on the infection. My first recommendation would be to ditch Trend Micro, and get a better antimalware program (it's not very good compared to alternatives). Much better alternatives include; 1. NOD32 (or if you want the suite, NOD ESS) www.eset.com 2. Kaspersky www.kaspersky.com 3. Avira www.free-av.com 4. Avast www.avast.com 5. Malwarebytes AntiMalware www.malwarebytes.org Each of these include trials and/or free versions that you can use to get rid of the infection. I'd also recommend following it up by posting a HiJack This log to one of the many support forums available, including TeMerc Internet Countermeasures; www.temerc.com/forums To do so, please see the following instructions; http://temerc.com/forums/viewtopic.php?f=12&t=18 A list of other trusted support forums can be found at; Alliance of Security Analysis Professionals http://asap.maddoktor2.com
Gateway GT5432... • Answered on May 27, 2008
it would help if you write the specs of the machine.. specially the MOBO (mother board) Model
Gateway GT5432... • Answered on May 02, 2008
Re boot usually fixes that issue.
Gateway... • Answered on May 01, 2021
why not ask at gateway (ACER is maker now)login and is best, tell them what you own.https://community.acer.com/en/search?adv=1&search=bios+password&title=&author=&cat=all&subcats=1&archived=1&tags=&discussion_d=1&discussion_question=1&discussion_poll=1&comment_c=1&comment_answer=1&within=1+day&date=the battery is deep inside, and must be replaced.only dismantling laps find it.what will be , will be on laptops.RTC 101 class:1:remove all bottom hatches find RTC Coin bingo.not found on AIO.2: remove keyboard see RTC bingo.(laptops only)3: if fail above,split the cases bingo RTC. coinbingo AIO PC.gateway and acer both are sux company. same. actually. NO SERVICE manuals offered.next time buy Dell.there are 4 kinds of RTC.1: none seen on note pads with main battery does same role.2: rtc coin obvious.3: RTC rechargeable even nasty NiMh, kind soldered down4: RTC with pigtails and wire plug.what you find is what you find. that is the rules.here. Gateway has no books worth squat.wow has 3 fans in this lil beast AIO.watching you tube russian take it apart now.All videos devoid of try full dissemble.the 6961 is here the COIN clearly seen,
Gateway... • Answered on Mar 24, 2021
answered for current hyjacker, fully.
01-E or 07-C? there seems to be variations on that model. Our computer guru Larry, will probably know if there are MANY more. Do you need drivers for the computer itself or a device that you have added to the computer? https://www.google.com/search?safe=off&rlz=1C1QJDB_enCA643CA644&sxsrf=ALeKk02vGYLXxrETayYXoTQq1L-c0eZ6tA%3A1614106243341&ei=g041YJeYFNiHwbkP6OKp8Ag&q=gateway+DX4831+drivers ..
Gateway... • Answered on Feb 23, 2021
A Payment Gateway is a middle-man that securely takes money from your customers and sends it to your bank account. ... Merchant securely transfers order information to the payment gateway. The transaction is then routed to the issuing bank or the 3D secure page to request transaction authentication. https://www.quora.com/How-do-payment-gateways-work-technically
Gateway... • Answered on May 10, 2020
A 504 Gateway Timeout Error indicates that a web server attempting to load a page for you did not get a timely response from another server from which it requested information. It's called a 504 error because that's the HTTP status code that the web server uses to define that kind of error. https://www.howtogeek.com/367129/what-is-a-504-gateway-timeout-error-and-how-can-i-fix-it/
Gateway... • Answered on Apr 15, 2020
it's easy to burn music into a cd
first make sure that your computer has a cd-r or cd-rw drive
second insert a blank cd-r or cd-rw into the drive
third find the music files you want to burn onto the cd
forth open my computer and start dragging the files onto the cd icon on my computer
once you have finished dragging your files open the cd on my computer and click on write files to cd,
Gateway... • Answered on Mar 31, 2020
Gateway GT5432 Refurbished AMD Desktop Computer - AMD Athlon 64 X2 5000+ 2.6GHz , 1GB DDR... Logo
14 questions posted
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
rolling back xp from vista
  • Computers & Internet
