20 Most Recent
Sumvision Cyclone Micro 2 Media Player Questions & Answers
Can't turn my External Hard Disc Drive off.
The HDD will spin up and may stay on for as long as the computer is connected depending on how the computer bios is set up.
I set mine to switch off 10 minutes after no activity. That gives the HDD time to write to it and check itself.
Sumvision cyclone mkv 2 enclosure will not conect
From this and several other posts you made on this device (I assume you are the same Anonymous poster), it appears you do not have a formatted hard drive installed in the unit, or you didn't know the computer is treating it as an external drive (even if it calls it an "unknown" USB device. Your computer is looking for the file system in the enclosure. The directions for finding the unit from a Windows computer (written for the mkv, not the mkv 2, but they would probably work the same) are given in the review article linked below. Note: if you don't find any "Unallocated" disk, look in "My Computer" for a drive that isn't your internal hard drive or other usual device. Probably all you have to do is save your media files to this drive and they will be available to play on your A/V system.
Sumvision Cyclone MKV Primus 1080HD media player
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
