20 Most Recent
Dell OptiPlex 260 PC Desktop Questions & Answers
My sound is coming after formatting my PC.
If i understand you correctly, you are saying that the sound is not coming after you reinstalled windows. The problem could be beacuse of missing drivers
You can try downloading the drivers from the following webiste
http://tinyurl.com/29mjtbg
Thanks for using Fixya
Proton
No power to front panel (power supply does work on
First pull out cmos cell from motherbord for 10 minutes .So all settings are defaults becaseu some times rong settings in bios create this problem.
Then check your cpu power supply unit. It is called SMPS is it working or not.
Try with other cpu SMPS unit.
Refix RAM memory to.
Cannot burn cd from Musicmatch from Dell Optiplex GX260. Error.
My name is ArmyMason, I am here to help you. So you have an issue burning music to CD's. What is the format of the music? MP3, WMA, or WAV? Is the music protected by copyright in which doesn't allow you to burn it to CD? Right click on the song and click properties you will be able to see if its copyright protected there. Also some burning software only works with newer CD drives. I had an issue once burning a DVD with this software I bought because the DVD player wasnt supported. Once I upgraded the DVD Burner I was able to burn DVD's. Those are the only things that could be stopping you from burning music.
Hope that helps,
ArmyMason
Deell opti-plex wont boot
try inserting your recovery disk. and make your cd rom your first boot device then press any key when you re-boot.
No boot
check your pc cmos batteryit might low. there might be shorting on board because of fungers on edges of ad on cards ormemory.please clean it
How do i get the computer to start up when all it does is flash the Dell logo
Larry provides great information.
Larry Ng Apr 30, 2022
good news the not told at all PC screen is not dead.
a major fact but lacks all evidence like:
1, No PC told no OS told xp to w11
2: fans spin? all do, psu ,cpu and gpu card if fan.
3: Optiplex is a desktop 29 years of models made wow.
4: you mean Dell Splash logo. yes, and then it does the post bar, if post bar stalls that means hardware gross errors.
sadly no PC model told of vast versions. wow.
just wow hopeless that.? but is par here, and vast wrong answers just for that fact alone.even mine.
i have many optiplex PC here old and new and my fav is 9020MT or smaller my oldest is 380(in storage)
is your coin cell dead. (if yes can NOT be ignored)
my dells all have F12 diagnostics,
power on and hammer F12,, pick diag eSPA and run it
older PCs dell if the HDD is dead the F12 diag is dead. due to being located there back long ago.
my dells have a BIOS log page,
go to BIOS the click tab, LOG
read the logs. see what fails. (coin cell RTC sure)_
easy no?\
but why on earth post lacking the model number
making any useful simple help 10 pages long for 29years of models.
1993 is the first OptiPlex, seen here.
https://en.wikipedia.org/wiki/Dell_OptiP...
nobody can guess
and no era is the same. evolution max.
Dell OptiPlex 3020 Desktop computer startup problem?
What is the exact error that you are getting? Do you get any blue screens? Have you installed any software recently or made any changes? I can only suggest checking the power cables and trying to use a different cable or spare if you have any for now.
I have forgotten my bios password
Desktops PCs usually have a 'jumper' on the motherboard, inside of the PC, that resets the BIOS, removing the password but also changing some settings to their defaults. It takes some 'know how' but you can google it to help you locate it.
