20 Most Recent Eclipse 180g2 4gb mp3 music/vid Questions & Answers
This issue is very easy to dispose of. A free online converter could assist you. Whatever the OS ur running on your computer, this Free WMA to MP3 Converter is available. Ive used it for many times. It is very helpful.
Eclipse 180g2... | Answered on Sep 16, 2019
its might because driver is out of date or needs fixed
Eclipse 180g2... | Answered on Mar 12, 2019
the mp3 player manual is located under the player in the plastic container with the earphones and the charger cord and etc.
This is caused from the player losing its format. When you plug it in clear that message and then go to the computer screen that shows all the drives and see if it is listed there. If it is, you can right click on the icon for it and select properties, you can then restore defaults on it and it should be fine. You then can reinstall the music and it should play.
Eclipse 180g2... | Answered on Feb 17, 2017
Take a toothpick and clean the auxillary headphone input
Eclipse 180g2... | Answered on Jul 16, 2015
RTM page 6 :>)
Power On/Off
To power the player on, set the power switch to the ON position, or press and hold the
PLAY button for 5 seconds, until you see the Eclipse screens. To power the player off,
press and hold the PLAY button for 5 seconds, or until the device powers off, then set the
power switch to the OFF position.
http://www.eclipsemp3.com/180G2.pdf
Eclipse 180g2... | Answered on May 17, 2015
Replace the battery (they don't last forever).
Eclipse 180g2... | Answered on May 12, 2015
Check if your files appear in computer as Removable Disk. Copy/pate or move your music to MUSIC folder of Eclipse
Eclipse 180g2... | Answered on May 06, 2015
Connect your Eclipse player to a computer and try to format it as a Removable disk. If can't, try low level format using HDD LLF Low Level Format Tool
http://hddguru.com/software/HDD-LLF-Low-Level-Format-Tool/
If still can'tt format it, probablt your Eclopse is unrecoverable. Actually, it's the WORST mp3 player I ever had!.
Eclipse 180g2... | Answered on Apr 28, 2015
According to my experience with Eclpise, you don't need to convert wma files to mp3. Just change the extension and your player would play them
Eclipse 180g2... | Answered on Dec 19, 2014
Connect it to your computer, open the Removable Drive, open music, video, etx. folders one by one and delete content
Eclipse 180g2... | Answered on Dec 10, 2014
Probably battery is dead. It is an internal battery and no way to change it so you lost your mp3 player and your money. Get a new onw, but not an Eclipse
You should copy music files to a folder called music.
Can't repair it. It is dead. If still on warranty, take it back where you bought it, they should change it. If not on watrranty, you lost your mone, buy some other brand.
You have some problem with Eclipse. If it is on warranty, take it where you bought it. It not, buy a new mp3 player. Any but not Eclipse
You should look in your computer's mainfolder for Retrivable Drive. Open it and look for a folder called music you should download your music there. If you can't find the "Retrivable Drive" in your computer, it doesn't recognizes your player, means it is not working. It it is new, should return it where yoou bought, for change
Look up in the setup menu
Eclipse 180g2 4gb mp3 music/vid Logo
131 questions posted
Top Eclipse Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you an Eclipse Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Eclipse Audio Players & Recorders
Most Popular Question
try sync music all eclipse says usb
  • Audio Players & Recorders
