20 Most Recent Zebra 203DPI Printer Questions & Answers
2answers
Hi all~ my zebra printer print blank non-stop everytime power on printer. we need send jobs first just can power on printer to stop printing blank non-stop.
When you power that printer on it will automatically calibrate which can kick out up to 6 feet(2 meters) of blank labels. After that is done if you have an issue it should display an error.
11/19/2015 4:58:20 PM • Zebra 203DPI... • Answered on Nov 19, 2015
3answers
My zm400 keeps reverting back to direct thermal
did it stay on direct thermal if you not doing any print job ?
then i assume you the problem is when you printing .In ZEBRA DESIGNER, there's a printing preference that can be set up... i think u selected direct thermal when you print with zebra designer, that's why whenever u start printing, it show RIBBON IN again.
the solution is, Just changed the printing method from zebra designer.
if you aren't using zebra designer, then the problem at your driver. Open Printer & Faxes, then right click your Printer and klik on Printing Preferenced. There u can set up the printing method to Thermal Transfer.
The thing is....... changing the Setting from LCD panel won't change the setting on the driver.
i hope this will help you
6/25/2014 7:42:26 AM • Zebra 203DPI... • Answered on Jun 25, 2014
0answers
3answers
How do I change the IP address on my zebra zm400.
Press on setup button
Press on the - button until you see protocol
Press on select and choose permanent and save
Press on the + button until see the IP Address
Press on select and use the + button to change numbers and Press the - button to move to the next number.
Press selects to save restart the printer by switching the printer on and off.
Test a print job to the Printer.
4/25/2012 5:56:14 PM • Zebra 203DPI... • Answered on Apr 25, 2012
0answers
2answers
I am trying to manually change the ip address in
First set I/P protocol to permanent and save. and then go back in and you should be able to see and change the IP , Subnet, and Gateway.
1/10/2012 9:11:06 PM • Zebra 203DPI... • Answered on Jan 10, 2012
Why the IP address cannot
I have the same problem before, but i change the IP through Zebranet view tools.You can install the zebranet view from the CD provided to your workstation and change the configuration according to the requirement with the zebranet view
9/7/2011 12:36:05 PM • Zebra 203DPI... • Answered on Sep 07, 2011
2answers
How do I change the IP address on the ZM400
Directly in Zebra, press Setup and 6 time the - .
You see Ip adress, gateway etc...
9/2/2011 6:22:33 AM • Zebra 203DPI... • Answered on Sep 02, 2011
I've got some problems with
The default setting is thermal transfer for this printer. You can change the setting on the printer so it doesn't show you the error any more by doing the following: Press SETUP/EXIT Press Plus (+) to scroll through the different parameters About the 6th parameter is "PRINT METHOD" Press "SELECT" to select the parameter Press Plus (+) or Minus (-) to change to Direct Thermal (no ribbon) Press "NEXT/SAVE" to save your changes If you make the changes to you printer and as soon as it prints it reverts back to thermal transfer, then your label software or your driver are overriding it and you need to make the change there.
Changing the setting in your label software - this will also change the settings for this label only Open your label Make the change under "label setup" or "page setup" inside your label software.
Changing the setting on the driver - this will also change the default settings for all future labels that you create Go to control panel and devices and printers. Locate the driver for your label printer and make the change under "Printing Preferences".
8/30/2011 6:05:44 PM • Zebra 203DPI... • Answered on Aug 30, 2011
Zebra 203DPI Printer Logo
41 questions posted
Top Zebra Office Equipment & Supplies Experts
David Shaub
Marvin
Marvin
Mehandi Husain ...
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Zebra Office Equipment & Supplies
Most Popular Question
zm400 keeps reverting back direct
  • Office Equipment & Supplies
