20 Most Recent
Epson Stylus C120 Color Printer InkJet Questions & Answers
Won't print blue
check the nozzle pattern once, and clean it until you get the test print fine( do this using printer program on maintenance tab).
Printing in magneta only
that means colors jammed, you need to do self cleaning few times, the manual will tell you how to do that. if still not working, send it to your local Epson service center or buy a new printerSmall tips for inkjet printer, power on and print couple pages every few days, your printer will last much more longer.
HOW DO I INSTALL MY
Hello, you will need to download your drivers online, use this link to download your drivers directly from the epson website:
Epson Stylus C120 Ink Jet Printer DriverChoose your operating system and click
go to view available drivers. Click the plus (+) sign next to your driver and then
click downloadThanks for using FixYa
On my Epson C120 I
open the printer properties on your laptop.
see the number port USB then equate with the USB port your plug in.
I get a double image with my Epson c120.
try doing print head cleaning.. the feature is under the printer properties , utilities tab... then once done.. print a copy of nozzle check..see if there is any missing line..
Epson stylus c120 lights flashing
I KNOW THAT YOU CAN RESET YOUR PRINTER SYSTEM ONLINE BY USING THE EPSON.COM SERVER AVAILABLE SOFTWARE, I JUST HAD MINE RESETED BY A FRIEND AND IS WORKING JUST FINE, AND STILL USING THE AFTERMARKET RESETABLE CARTRIDGES..
Have just replaced cartrideges in my C 120 and
Hi There
Summary
Usage of compatible ink and leave the printer idle too long may cause printhead clogging
What should you do if you get this problem. Relax; you may recover the printhead by unclogging it. Follow these steps to unclog the printhead
1. Right click in the printer driver name
2. Select Properties menu
3. Click Maintenance tab
4. Click on cleaning sign for regular cleaning. Perform this up to 3 times.
5. If this does not work, perform Deep Cleaning
And if that not work
Some times it needs a good clean up but this is up to you if you want to do this,
But after you done this prime the printer so it gets the inks back in the heads, it may take a little time for the inks to work.
Ok.
There is fluid cleaner for this but I can never find any in the shops the only ones I seen is when they sell them in Tesco but they come in with the ink refill bottles so I just use worm water by it self on a cloth and dabbing on the heads to clean them, it will not harm the heads but not to much water.
Some heads are on the inks them self but some have them inside the printer so I not know your printer so if the heads are inside you need to get them out you may find that some heads will just clip out put some need to be unscrewed so you got to know how they come out so be careful and not push to hard on them, if the heads are on the ink then it is a easy job to clean them,
It worth a try it worked for me more than ones.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
I need assistance in how to refill my t0731, 0732,
You probably do not want to hear this but re-filling your cartridges is the quickest way I know to wreck your printer.... as galling as it may be, get the original ones, it will save you heaps of problems later on.
Don't know where the refill hole is? Epson stylus c120 ink refill
The Epson 68 cartridges cannot be legally refilled at this time. There are two chips that monitor the ink levels. Once the ink gets below 25% the inner chip deactivates the outer chip so it cannot be reset. Any replacement chips you can buy are technically violating patent law. To refill these you would need a chip resetter and always refill it before it gets below 25%. I own a Cartridge World ink refilling store and I would not recommend refilling these yourself unless you enjoy getting ink everywhere and possibly still not having the cartridge work (btw there is no "refill hole" you make it yourself, thus the messiness).
