20 Most Recent Epson Stylus CX4400 All-In-One InkJet Printer Questions & Answers
If its Printing Like that it definitely has to do with the printing queue.
In this case what i would Request u to do is. Goto Control Panel goto Printers folder. There u will see the Printer Icon. Just right click on the Printer Icon and click on Properties.Now click on Advanced and goto Print Processor.Change it to Printer Name and Win print Raw.Click on Apply click Ok now try to Print.
Good Luck!!!!
Epson Stylus... | Answered on May 14, 2013
Clean the head off where the black is with rubbing alcohol and a qtip. If it won't detect the black cartridge and you went into the printer settings and enabled the black to print as well as the color, then the printer sensor that senses new cartridges and amount of ink level is defective and, unless it is under warranty, it's not worth fixing.
Epson Stylus... | Answered on Jul 21, 2011
Try to clean the print head using the epson utility or replace the ink cartridge.
Epson Stylus... | Answered on Apr 06, 2011
Your documentation and drivers can be downloaded right here:
http://esupport.epson-europe.com/ProductHome.aspx?lng=en-GB&data=lkuCfcvA9cyrA1FE2Kk6d68TKZC9NhDO&tc=6
If you need more help just let me know.  BTW, when you install printers, always have them unpluged from the PC until it tells you to plug them in.
Epson Stylus... | Answered on Dec 22, 2010
Normal 0
The computer does not know this model printer and gave the closest match.
You can download the Epson printer drivers from their support WEB site. Please click on this link and select your model printer to download :-
http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
Epson Stylus... | Answered on Oct 24, 2010
Go to Epson Support
Epson Stylus... | Answered on Oct 06, 2010
Since you don't have the setup disc for this printer and you want to install it to your computer , you need to download the printer software from this link.
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?oid=87588&prodoid=63070161&infoType=Downloads&platform=Windows
Epson Stylus... | Answered on Aug 20, 2010
Check out this guide. It features all the things that can be done with CX4400. Scanning a document is on page 15.
http://files.support.epson.com/pdf/cx44__/cx44__qr.pdf
Thanks
Epson Stylus... | Answered on Jul 11, 2010
it's due to u r nt able to insert the paper properly or ur printer cartridges are nt properly align
Epson Stylus... | Answered on Mar 24, 2010
Depending on where you live, your best bet is to take it to a place that refills cartridges. I never had any luck with refilling them myself.
Epson Stylus... | Answered on Mar 18, 2010
Forgive me for asking this, but roughly speaking about 80 to 85% of problems involving ink or toner are resolved by the following:
Are you using a manufacturer’s factory new ink cartridge or toner? I
f you are using a refilled (worst possible choice) cartridge , toner or ink, or third party cartridge (2nd. worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Epson Stylus... | Answered on Feb 27, 2010
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Epson Stylus... | Answered on Jan 20, 2010
Ink cartridge is not seated. Take it out and push in until you hear a click. Get a CISS for your printer. It will save you TONS of MONEY, never change a cartridge again and it will pay for itself in a month.
http://www.inkproducts.com/ink-store/
Epson Stylus... | Answered on Aug 05, 2009
Print From Your Computer : Windows Printing Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. 1. Select a Quality Option that matches your document or photo, and the print quality you want. Quality Option settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032347", false); WebWorks_WriteDIVOpen("wwdd1032347", false); • Draft: for rough drafts with reduced quality • Text: for documents containing only text • Text & Image: for documents with text and images • Photo: for photos and graphics with good quality and print speed • Best Photo: for photos or graphics with high print quality WebWorks_WriteDIVClose(); 2. Select the paper Type setting that matches the paper you loaded. 3. Select the paper Size setting for the paper you loaded. Paper size settings WebWorks_WriteArrow(WebWorksRootPath, "wwdd1032380", false); WebWorks_WriteDIVOpen("wwdd1032380", false); You can load paper in these sizes and select the size in the printer software. (Wider papers are for use only when reducing large images with the Reduce/Enlarge Document option.) A User Defined option is also available so you can create a custom size. A4 (8.3 × 11.7 inches) A6 (4.1 × 5.8 inches) Letter (8.5 × 11 inches) Legal (8.5 × 14 inches) Half Letter (5.5 × 8.5 inches) 3.5 × 5 inches 4 × 6 inches 5 × 7 inches 8 × 10 inches 16:9 wide (4 × 7.11 inches) Envelope #10 (4 1/8 × 9 1/2 inches) WebWorks_WriteDIVClose(); 4. If you’re printing borderless photos, click the Borderless checkbox. For documents or photos with borders, select Borders. Note:
For borderless photos, make sure you loaded a compatible borderless paper size and type. 5. Choose Portrait or Landscape orientation for your document or photo. You can also:Select Print Options Select Basic Options Click the Main tab on the top of the printer settings window to select your basic print options. Select graphics & text. USER'S MANUAL EPSON WEBSITE: http://files.support.epson.com/htmldocs/cx44__/cx44__ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Epson Stylus... | Answered on Jul 22, 2009
http://files.support.epson.com/pdf/cx44__/cx44__pg.pdf
refer to page 8
Epson Stylus... | Answered on Jul 16, 2009
You may want to reset or power cycle the printer. Please follow the steps below:
1. Turn off the printer.
2. Unplug the power cord from the wall power outlet for 10 minutes.
3. Turn the printer back on.
If you get the same problem, try cleaning the printer head.
Hope this helps and have a great day!
Epson Stylus... | Answered on Jul 09, 2009
plug the printer back on
in the printer setup there is a tab that says
test print.
you can test one by on
head test
nozzel test
ink test
go have a look there
Epson Stylus... | Answered on May 20, 2009
Epson Stylus CX4400 All-In-One InkJet Printer Logo
Popular Tags
42 questions posted
Top Epson Office Equipment & Supplies Experts
Ekse
Muntejaya Ginting
Muntejaya Ginting
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Stylus Epson
  • Stylus Epson
Most Popular Question
no istaller epson stylus cx4300
  • Office Equipment & Supplies
