20 Most Recent Canon SELPHY CP740 InkJet Photo Printer Questions & Answers
I've just had this same problem with my Sephy 740. Nothing helped until I disassembled the printer and realizing the small gear wheel (not visualized) at position in the red circle had loosened. Remounting the gear wheel on the shaft with a tiny drop of Blue Loctite and letting dry three hours, reassembling the printer and turning it on fixed the problem. 3af8395c-7fdb-4b3e-b7a3-4a180b0a0d40.png
Canon SELPHY... • Answered on Nov 23, 2020
What printer? Fairly critical detail no?
Canon SELPHY... • Answered on Apr 02, 2017
Replace the ink-cartridges, to see if that fixes the problem. Check the printer setup to see if it is in "draft" mode or "normal" mode.
Canon SELPHY... • Answered on Feb 24, 2015
I doubt very much that you need to reset the printer, or, even if you did, that this would make much difference. It sounds as if there is a menu item which you should be able to bring up on the display which then allows you to release and extract the cartridge. I have scoured the web for information on this one and Canon, naturally, only supply the software, not the manual. If you have a manual can you look up and quote the relevant bit in it which deals with changing the cartridge? If there is nothing there which says that you have to go to a menu item to release it then it sounds like a mechanical problem - as in 'needs a bit of a yank'. I'll keep looking.
Canon SELPHY... • Answered on Aug 25, 2013
When my printer does that it mean you need more ink
Canon SELPHY... • Answered on Aug 07, 2013
You may download a copy of the manual from here.
Canon SELPHY... • Answered on Sep 25, 2012
I encountered this issue with a Selphy CP800 and I presume the reason is the same; it seems to be a common problem. Canon tech support says that Selphy printers need exif data "just so" in order to generate screen previews. If all you do is copy your image to a flash memory device from your camera card, you may well be OK. But if you edit the images (e.g. in Photoshop) you will very likely alter the exif data so that Selphy cannot generate previews from flash media plugged into Selphy. If you are copying images back to a **camera** SD card you may also have to make sure that you don't alter the file structure already present on the card. There are undoubtedly other ways to louse up the exif data of an image so that you can't get a screen preview. Workarounds: 1) official Canon advice is to print the image directly from your computer - that's what tech support told me; 2) if you own Canon's Digital Photo Professional Software you can rebuild the exif data by using File>Convert and save>kind of file = exif-jpeg - this worked for me; 3) Graphic Converter for Mac now has a way of rebuilding exif data according to a poster on the Apple discussion boards; I could not test this out b/c my (old) version of Graphic Converter, 5.4, does not have this capability; 4) if you get a screen question mark, the image will still print - you just can't see the preview. This is only a problem if there's more than one image that generates a question mark on your flash media device because you can't see what image you're printing. So if all else fails and you have to print from flash media, you can put a single image with screwy exif data on a flash drive and be confident that you know what you're printing.
Canon SELPHY... • Answered on Mar 28, 2012
Canon SELPHY CP740 InkJet Photo Printer Logo
41 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
SELPHY Canon
  • SELPHY Canon
Most Popular Question
manual canon pixmaip3000
  • Office Equipment & Supplies
