20 Most Recent
Sharp LC-52LE810UN LCD TV, 52 - widescreen Diagonal Size, TFT active matrix Technology, 1920 x 1080 Resolution, 1080p FullHD Display Format, 16:9 Image Aspect Ratio, 120 Hz Enhanced Refresh Rate, 10-bit color Color Depth, 4000000:1 Dynamic Contrast Ratio, Questions & Answers
Connecting LC-52LE810UN to internet
Connecting to the Internet
To connect your TV to the Internet, you must have a broadband Internet connection.
Use an ETHERNET cable (commercially available) to connect the ETHERNET terminal on the TV to your
broadband router (commercially available).
If you do not have a broadband Internet connection, consult the store where you purchased your TV or ask your
Internet service provider or telephone company.
you need to have a cable connected to the ETHERNET port and then you will get more options. You need to connect it to your router ports. hopefully you have DHCP enabled on the router and then all will program automatically
2/1/2014 3:54:52 AM •
Sharp...
Answered
on Feb 01, 2014
Sharp model GX-CD 610 GY has error 000 what does error 000 mean
The basic binary errors are usually something small. 0000 is usually a cleaning error. I would try to clean the lens with the recommended cleaner and then try again. If problem persists the lens may be saying its dirty due to a scratch on it. These are hard to diagnose because it's a process to remove. I would clean it then replace the lens if needed.
