20 Most Recent
Sharp CD-MPX850 Shelf System Questions & Answers
THE SYSTEM SHOWS ME ER-CD01
this is a standard reset so if its a problem with the programming this should do the trick if it does not either your cd or laser lens is no longer doing its job properly
turn on the set-press the on stanby button,allow the set to enter demo
mode. now press the power button while
pressing the stop and eject button,clear all will display
hope this helps
Robb
My sharp cd-mpx850 won't turn
The cause could be a blown fuse or the power transformer that has a built in thermal fuse has opened preventing power to the rest of the stereo. The main unit must be taken apart to assess the amount of work needed and to check for secondary problems.
I CANT GET THE FM/AM BAND TO WORK
Connect a good FM antenna to the unit's antenna jack to make sure you get good radio reception. Power on the unit. Press the Tuner/Band button. Adjust volume and tune to a known station using the up or down arrow buttons..
