20 Most Recent JVC GR-AX640U Camcorder Questions & Answers
manual
I have a jvc camcorder model gr-d350u that will not come out of safeguard mode
Not sure , do you mean safe mode ?
1/24/2019 4:34:16 PM • JVC GR Video... • Answered on Jan 24, 2019
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery. Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
11/13/2017 11:45:25 AM • JVC GR Video... • Answered on Nov 13, 2017
Not used my vid cam for a long time but when played back some tapes played great. The following day I tried playback on the tapes & they all showed a blue screen. No images What am I doing wrong?
not sure on this one but it might be the heads in your vid cam may need cleaning. or the tapes are not running straight on the heads or the rollers in side. if the vid cam has been in a cold place it can cause this fault as the heads may have a bit of damp. try putting a tape in and run it fast forword in play mode and see if starts to clear the playhead.if it does keep doing it until you see a clear picture. this could also be a head misalignment fault if it is you will have to take it to some one to have a look at. if any of the above does not work then you will have to take to some one to look at it. .
11/27/2016 9:48:19 PM • JVC GR Video... • Answered on Nov 27, 2016
Cmy JVC camcorder will not start is model GZHdaA
Sounds as if the battery needs replacing - have you tried with a spare battery ?
10/8/2016 12:49:40 AM • JVC GR Video... • Answered on Oct 08, 2016
0answers
I have bad audio static when playing my mini dv tapes on two JVC MIni DC Video cameras model GR-D244U and GR-D370U,need help?
The heads need cleaning. DO NOT USE A HEAD CLEANING TAPE. Thats like holding sand paper to the drum. Use alcohol and a swab.
9/12/2016 6:26:58 PM • JVC GR Video... • Answered on Sep 12, 2016
I misplaced mysoftware disc fr the camera and just bought a new computer. how can I retrieve pictures from my camera onto my desktop?
Do you have the sd card that holds the pictures? Put in computer. Computer will give you option how to open and save photos. You do not have to use makers software disc, any photo reader can store your pictures on computer.
11/28/2015 3:09:03 AM • JVC GR Video... • Answered on Nov 28, 2015
Montgomery Ward Signature 2000 HQ Movie Video System VHS Camcorder JMJ 10652
How much would one be worth today
7/26/2015 2:44:15 PM • JVC GR Video... • Answered on Jul 26, 2015
What software do I need to transfer tapes from gr d240 mini DVC to desktop PC
Your PC must have a IEEE1394 port (FIREWIRE PORT). If you do not have, you can try PINNACLE DAZZLE to video capture.
2/11/2015 5:03:24 PM • JVC GR Video... • Answered on Feb 11, 2015
2answers
How to Convert My ALS Charity AVCHD from Sony A5100 to iPhone
iPhone can not play AVCHD format directly. You may need to convert it first. Transfer videos from your digital camera to your computer, then convert AVCHD to mp4 or mov format. Last but not least, transfer videos to your iPhone via iTunes. How to Convert AVCHD to MP4 for Free
1/20/2015 9:23:59 AM • JVC GR Video... • Answered on Jan 20, 2015
My GR_SMX730U VHS camcorder is eating the tape.It uses a PRO TC-30 casset.
that means the head is sticky or the takeup rollers are icky take it apart . clean all the parts the tape touches with something thats strong but little water . as for the head very carefull clean it when you get to the actual holes where heads are only use a proper qtip wetted . look it up or youll break them. on the rubber rollers scrub them . then load the tape an watch it run. its easy to fix this but you need a nice clean place an some small phillips , take pics of parts/screws if needed
1/12/2015 11:02:24 PM • JVC GR Video... • Answered on Jan 12, 2015
I need a manual for jvc GR- SXM340
Manual for this camcorder can be downloaded here for free http://books.jvc.com/booklist.asp?Model=GR-SXM340
11/26/2014 5:07:54 PM • JVC GR Video... • Answered on Nov 26, 2014
Tape won't eject on my jvc gr-d60. help please.
Remove battery Press and HOLD Eject as you place battery back on (so its the first command it recognizes with power) and try to eject. If it does not come out, camera will need service to remove tape or fix gears
11/26/2014 5:06:52 PM • JVC GR Video... • Answered on Nov 26, 2014
Camera says lens cap on when its not
Lens Cap Error can happen when "eye" of camera goes out "blind". this will require service on the CCD.
10/20/2014 4:01:50 PM • JVC GR Video... • Answered on Oct 20, 2014
JVC GR-AX640U Camcorder Logo
0 questions posted
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marco Avila
Marco Avila
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GR JVC
  • GR JVC
Most Popular Question
connect old camcorder new pc
  • Video Cameras
