20 Most Recent
JVC GR-D244US Camcorder Questions & Answers
CAMCORDER WILL NOT PUSH IN A TAPE, STUCK HERE
Posted by delmas263 on Jan 02, 2009
I have the same problem, The camcorder will not take in the tape, stuck the tape holder will not go back in, notify me when you have a solution. Thanks
When camcorder plays my movies
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Ys lense cap i it is not
Do you mean no lens cap attached but it shows remove lens cap? If so, most likely your CCD needs replacement. Consult your nearest JVC Service Center
Why won't my digital camera charge via USB anymore?
Take camera and its battery to a camera outlet, ask them to check the built-in rechargeable battery.
Most outlets will help you with this, as its likely that if the battery has failed, you'll buy a replacement from the same dealer.
My GR_SMX730U VHS camcorder is eating the tape.It uses a PRO TC-30 casset.
that means the head is sticky or the takeup rollers are icky
take it apart . clean all the parts the tape touches with something thats strong but little water .
as for the head very carefull clean it when you get to the actual holes where heads are only use a proper qtip wetted . look it up or youll break them.
on the rubber rollers scrub them . then load the tape an watch it run.
its easy to fix this but you need a nice clean place an some small phillips , take pics of parts/screws if needed
