20 Most Recent JVC GZ-MG130U Camcorder Questions & Answers
Here is the step-by-step introduction for you:
Step1. Download, install and then launch Video Download Studio from http://www.downloadvideos-convert.com/download-videos-music.
Step2. click” add” button to load your files to Video Download Studio.
Step3. Click “convert” button on the top to switch to convert interface.
Step4.click on the videos, choose them as the conversion file.
Step5. Click the drop-down list to select the AVI format for each video.
Step6. Click” convert” button at the bottom to begin the conversion. Video Sharer will convert your videos one by one. After the task finished, you can find your videos on the conversion file.
Video Download Studio features:
1.Video Download Studio with easy and simple user interface supporting a wide range of video formats including AVI, MPEG, MP4, 3GP, WMV, MP3, FLV, MOV, WAV and more.
2.Provides popular out video formats including AVI, WMV, MPG, MP4, MKV, SWF, FLV and popular audio formats including MP3, M4A, WAVE, WMA. Supports video trimming to convert any part you need of the original videos.
Do not hesitate, come and get one for free. You will love it after you try it.
JVC GZ-MG130U... | Answered on Nov 06, 2019
Sounds like it is time for a new camera.
JVC GZ-MG130U... | Answered on May 04, 2017
Connect a what to what ?
JVC GZ-MG130U... | Answered on Apr 25, 2017
I had success with this
1. Do not save any new file to memory card.
2. Connect your card to computer. You should see memory card shown as a drive letter (like H:) in My Computer.
3. Download recovery software, recommended one is this photo recovery (simply because i was using it and it worked)
http://www.asoftech.com/apr/
4. Install and open the photo recovery program, select your memory drive, and click 'Start' button to start scanning process which will find your deleted photos.
JVC GZ-MG130U... | Answered on Feb 08, 2014
The message is clear. You cannot use the card.
You can check the manufacturer's website to see if there a new firmware. If there, is update the firmware (anyway) and hope it will support the card format. If there is no new firmware, read the manual for the type of cards and capacities supported and buy compatible cards. The old card can be returned to the store, sold to someone, or saved for future devices.
JVC GZ-MG130U... | Answered on Jan 11, 2014
I understand that you wish to Pause and Continue recording to record several scenes in a single file. Unfortunately, HDD Camcorders(regardless of manufacturer) do not have the option to pause and record in a single file. Once you press STOP, it will save the current file and When you press the Record again, it will start record as a new file. This is because of the characteristics of the HDD media. If you wish to have the video as a single file, please use a video editing software to combine the videos.
Thanks for understanding. Please let me know if you require any clarifications.
JVC GZ-MG130U... | Answered on Jul 06, 2011
You can download the manual and more from the manufacturer's web site at
http://books.jvc.com/booklist.asp?Model=GZ-MG130US
JVC GZ-MG130U... | Answered on May 07, 2011
Is it JVC GZ-MG130U camcorder or any other model?
If it is above said model then lens cover would have dust particles inside and requires cleaning. Camcorder cabinet will take apart to take off front cabinet assembly to clean lens cover parts. Please confirm model number of camcorder to provide you disassemble pdf file that has detailed exploded views that will help you if you want to clean lens cover slides by yourself.
Thanks.
JVC GZ-MG130U... | Answered on Mar 30, 2011
Download Nero 8 or Nero 9.You will get a option in that software to burn to a DVD Video Disc.
The format for DVD Players are AVI,MPEG-2,DivX depending on your DVD player
Thank You.
JVC GZ-MG130U... | Answered on Feb 15, 2011
Download and install Google Picasa. It will allow you to import and create DVD's: http://picasa.google.com/intl/en/
JVC GZ-MG130U... | Answered on Jan 02, 2011
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Thanks for using FixYa.
JVC GZ-MG130U... | Answered on Oct 29, 2010
That's a bummer. I have the same camcorder and yesterday 10-3-2010 mine did the same thing. I deleted some files from the file folder located on my camcorder from my computer (which I learned not to do), went to the disconnect device on the computer and it said "safe to disconnect" so I did. The screen on the camcorder said "connecting to device" the whole time I was transferring files to my computer and after my computer said it was safe to disconnect. After it was safe to remove my camcorder, I unplugged the usb cable and tried to turn off the camcorder and nothing happened. I removed the wall charger and battery which finally turned off the camcorder. I then tried to turn the camera on and same thing as you, Everio sign came on and then the screen went blank. Nothing was accessible after turning the power on. One time an error sign appeared saying something like disc broken, need to restore disc to record video. I tried everything, turning on with wall charger and no battery, pushing buttons while it was turning on, holding down buttons, etc. Finally I tried something that made it work. Don't know exactly what I did, but it started working.
Solution: With the power in off position and the battery removed, as well as the wall charger cable removed, I flipped open the screen, opened the lens, connected the wall charger, turned switch to on position and let it run its coarse. It was on for 5 mins or less then shut itself off. I then flipped the switch to off, let it sit for a few minutes and turned it back on, while it was booting up (this part has no logic behind it) I pushed the "plastic" lock buttons for the battery and a screen appeared asking me if I wanted to restore the hard drive. I quickly clicked yes and all is well. The camcorder is back to factory settings but it at least works. Luckily I copied everything before it crashed. The key for the future is to not delete files from the camcorder while it's connected to your computer.
Sorry for the long post, but hopefully it helps.
Eric
JVC GZ-MG130U... | Answered on Oct 04, 2010
This is usually caused by a defective CCD image sensor and can be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
JVC GZ-MG130U... | Answered on Sep 27, 2010
Possible that the trigger is not activating on the microprocessor to give the control to the servo section to pause.
So you might need to open and check this delicate section with great accurracy so as not to tamper.
Hence my advice is to seek help from JVC service support.
JVC GZ-MG130U... | Answered on Sep 13, 2010
My first concern would be regarding the actual working of the microphone on this unit. If the sound is so muted that the volume has to be at maximum then the microphone is probably the real culprit. Try using an external microphone and running a short test film.
Download the faulty video to your PC and see if it actually plays properly through Winamp or whatever you have to view video.
Please rate my help++++Thanks for using FIXYA
JVC GZ-MG130U... | Answered on May 19, 2010
JVC GZ-MG130U Camcorder Logo
44 questions posted
Top JVC Video Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
View Most Popular
GZ JVC
  • GZ JVC
Most Popular Question
recover pictures
  • Video Cameras
