20 Most Recent Alpine PDX-1.600 Car Audio Amplifier Questions & Answers
It has power but it may not have any input and without a good look myself i wouldnt know offhand as to where to tell you were to look sorry
Alpine PDX-1.600... | Answered on Oct 06, 2015
needs more power, or how your wired impedance is too low.
1.upgrade your power cable
2.buy a second battery not a capacitor
3. run power cable to the second battery from the + of the from battery the battery from the front
4. run at minimum of 4 gauge power wire
5. run 4 gauge wire from the alt to the main battery
6 run 4 gauge from the negative of the battery to the ground chassis
7. run 4 gauge + to the rear battery
8 run 4 gauge ground near your amp
9. turn down the gain and bass boost, set it a moderate level where you wont hear distortion
10. set the bass level from your stereo deck at a moderate level also.
find your impedance.
look at your woofers and find have a number like 1,2,4 ohm.
find out what your amplifier minimum needs to operate in OHM's.
look here.
http://www.the12volt.com/caraudio/boxcalcs.asp
Alpine PDX-1.600... | Answered on Nov 15, 2013
This really sounds like some component in the amplifier circuit is breaking down under a load, which would require servicing, but I ran across this blog on the web, and they seem to think it's related to the gain, so it might be worth reading:
http://www.caraudioforum.com/showthread.php?t=318023
Good luck, and hope this helps,.
Alpine PDX-1.600... | Answered on Oct 03, 2010
Make sure there's no missmatched impedance. If your sub running 2 ohms then your amp has to be 2 ohms stable. Does the amp blow fuses or get really hot? If it does it can be a fire hazard and I would recommend taking it out of your car. It could be that you don't have sufficient grounding. The grounding needs to be very close to the amp and the paint needs to be thoroughly scratched off. Otherwise could be a blown transistor within the amplifier, you can check this by opening up the amp, running a multimeter and testing the transistors for resistance.
Alpine PDX-1.600... | Answered on Aug 05, 2009
ur speakers are probably connected wrong so diconected and and connected differently. and if ur speakers a dual coil see if they connected it if not do this. only if ur speaker is double coil meanin if ur speaker has 4 connections for speaker wire. and if it does than connect possitve to negative from one coil to another and negative to positive from the other one than from one of the coils connect the wires going to ur amp positiv to positiv and negative to negative bringind the sub to 2ohm constant
try that see if it works. only if u have a double coil subs
Alpine PDX-1.600... | Answered on Jul 09, 2009
You are going to want to make sure all your power wires and grounds are 4 gauge as well as the wire leads to and from the capacitor-4 gauge also. make sure you have a very good ground - the power wire from the battery should hit a distribution block-from the dist. block a 4 gauge should go to the capacitor another 4 gauge to the mono amp and another to the 4 channel amp -every component should have a good solid ground even if you have to bust out a grinder and a drill and some self tapping sheet metal screws and go nuts on it- see if that helps you
Alpine PDX-1.600... | Answered on May 27, 2009
Hello zim69zim69zi,
Solid red indicates 4 possible conditions: 1) Short circuit, 2) Current too high, 3) Voltage too high, or 4) Overheated. The most common faults are the short and overheated.
If the fault is intermittent, the amp is probably overheating. If it is a constant fault, anytime the amp is powered up, then I'd recommend that you first check all of the wiring. If the wiring is OK, then you have a voltage or current problem. If it's voltage, the vehicle electrical system is probably causing it. You can check that with a meter. It should be from about 12VDC with the engine off, to about 15VDC with the engine running (alternator putting out). The amp should be able to operate OK up to about 16VDC but as components age, their values change. I'd look for a minimum of 10.8VDC and a maximum of 14.8VDC.
If the problem is overcurrent, the amp itself probably has a defective component causing it to draw too much current. It needs professional repair.
Hope this helps.
Alpine PDX-1.600... | Answered on May 16, 2009
you need more batt, more amps, try new batt, capacitors are paperweights, spend on good batt.
Alpine PDX-1.600... | Answered on May 14, 2009
check your coil wires on the back of the sub
Alpine PDX-1.600... | Answered on May 07, 2009
What is the code of bontec alpine a06012 car stereo
Alpine Car Audio... | Answered on Nov 03, 2020
Frankie. I am having the same problem. Did you find an answer or do I need to get a new power pack or control unit?
Alpine Car Audio... | Answered on Aug 15, 2020
I can't find the power wires on my Alpine CDA 7894
Alpine Car Audio... | Answered on Apr 17, 2020
Alpine PDX-1.600 Car Audio Amplifier Logo
15 questions posted
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Alpine Car Audio & Video
Most Popular Question
alpine pdx1 600 amp cuts off
  • Car Audio & Video
