20 Most Recent Nikon COOLPIX 5100 Digital Camera Questions & Answers
All of a sudden my pictures wont upload to my laptop. How do I fix this?
Update drivers!
8/23/2015 12:56:14 AM • Nikon COOLPIX... • Answered on Aug 23, 2015
Lens jammed will not extend
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
9/28/2011 1:03:53 AM • Nikon COOLPIX... • Answered on Sep 28, 2011
I have a nikon 5100
there is something wrong with your camera shutter shutton or lcd screen or any other parts. you need send it to the maintance center,the repairer will offer you the final answer.
www.skiliwah.cn/
http://www.digitalcamera-parts.net/
[email protected]
8/22/2011 3:11:40 AM • Nikon COOLPIX... • Answered on Aug 22, 2011
I lost my software of
Welcome to Fixya.
This is where you can download all necessary tools/software for your camera :
Nikon Support Page
For the imaging tools, just look under "Software" tab. For the complete user's manual, look it up under "Support" tab.
Thank you for using Fixya.
6/14/2011 10:33:51 PM • Nikon COOLPIX... • Answered on Jun 14, 2011
I have a camera with a cracked screen
Download from the following site:
http://support.nikonusa.com/app/answers/detail/a_id/14391/~/user%27s-manual---coolpix-p5100---guide-to-digital-photography
1/10/2011 9:53:43 PM • Nikon COOLPIX... • Answered on Jan 10, 2011
When reviewing the pictures I have taken on the
Sounds like the files are being corrupted, likely during the download process. How do you download your pictures? Do you attach a cable to your camera, or do you use a card reader? If it's the first, then that could be your problem. Please see this link describing the most error free way to download your photos. USB card readers are extremely inexpensive these days, with cost not an issue. But if a card reader doesn't help, next focus should be on checking for malware on your computer which may be interfering with the download. And finally trying a different card as the card may be failing (this is least likely but still possible).
12/5/2010 6:58:11 PM • Nikon COOLPIX... • Answered on Dec 05, 2010
The lens won't open or
This generally means that there is something in the way of the gears in the lens or they are just stuck. Simply pick up the camera like you are going to take a picture, hold onto it with only your right hand and then smack the bottom of the camera on the palm of your other hand. This should free up the lens and get rid of the error. Let me know how it works out and if you need anything else.
Benjamin
11/4/2010 4:44:26 AM • Nikon COOLPIX... • Answered on Nov 04, 2010
The camera will not turn
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
8/23/2010 5:05:11 AM • Nikon COOLPIX... • Answered on Aug 23, 2010
I need software for a Nikon Coolpix S550.
http://support.nikontech.com/app/answers/detail/a_id/61
7/20/2010 4:59:14 PM • Nikon COOLPIX... • Answered on Jul 20, 2010
What can I expect to Pay for a Coolpix P5100
Somw where around $350 would be an nominal cost i believe..
6/7/2010 4:54:32 PM • Nikon COOLPIX... • Answered on Jun 07, 2010
We have a nikon coolpix 5100, when i turn it on,
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
3/28/2010 4:08:06 AM • Nikon COOLPIX... • Answered on Mar 28, 2010
Nikon Coolpix 5700 - Lens Error
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
2/22/2010 9:51:00 PM • Nikon COOLPIX... • Answered on Feb 22, 2010
Can't rotate video
You really can't rotate a video. When was the last time you saw a movie or a TV show in portrait mode instead of landscape mode?
You may be able to use a video editing program to do this. You're certainly not going to do this in your camera.
12/30/2009 12:14:58 AM • Nikon COOLPIX... • Answered on Dec 30, 2009
My camera suddenly displayed the
You should take it to some authorized service center, there is a possibility that they repair it. It may be expensive so better buy a new one. Or try one thing just hold the preview button to power it on ( not the usual power button).
11/27/2009 2:52:42 AM • Nikon COOLPIX... • Answered on Nov 27, 2009
"OUT OF MEMORY" Error Message
Have you used formatted cards? It may be that due to the incorrect memory card - the camera defualt memory has changed to the camera - Can you check the settings?
5/12/2009 1:32:37 PM • Nikon COOLPIX... • Answered on May 12, 2009
Digital Camera Problem
this may sound violent and stupid but have you tryed pushing the lense back in. if the company refuse to fix under warrenty and your not going to pay the. its not going to change anything if it doent work
3/24/2009 1:12:51 PM • Nikon COOLPIX... • Answered on Mar 24, 2009
Trying to get owners manual
3/24/2009 1:07:55 PM • Nikon COOLPIX... • Answered on Mar 24, 2009
My digicam nikon coolpix 5100 showing memory card
try taking out the card giving the contacts on the card a wipe then replace it.
somtimes dust seems to gather on them
3/24/2009 1:00:40 PM • Nikon COOLPIX... • Answered on Mar 24, 2009
Nikon COOLPIX 5100 Digital Camera Logo
29 questions posted
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
lens open or
  • Cameras
