20 Most Recent Kodak EasyShare C513 Digital Camera Questions & Answers
Don't try to find drivers for Windows 7 or 8, because when there are drivers they are available on the Microsoft site. It is not possible to use drivers made for XP in newer operating systems. Not even in the compatibility mode. It is a pity, Kodak stopped the support for their easy share software. If you can't get software form your brand, you always can install other generic software like Ulead, Pixir, BeFunkey, Gimp, Photoshop express. Or if that is not possible you could install an external memory card reader and download the pictures via de memory card reader.
Kodak EasyShare... • Answered on Apr 10, 2015
it can be fixed, u just need to change the LCD screen that is on the camera. its very easy to change. i can help u with all the supplies needed or u can take it to the service center & get it done. if u r interested in the supplies & want to do it yourself that u can comment back here
Kodak EasyShare... • Answered on May 12, 2014
Maybe you can try to download them to a thumbdrive through your computer and then bring that down. Or, bring the camera down and see if they can help you.
Kodak EasyShare... • Answered on Nov 21, 2012
Turn off "kodak software" in PC mode. It may be trying to find you Kodak Easy Share program on your computer that has not been installed.
Kodak EasyShare... • Answered on Dec 14, 2011
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Kodak EasyShare... • Answered on Aug 17, 2011
You can download Kodak software from
http://support.en.kodak.com/app/answers/list/c/890
Kodak EasyShare... • Answered on Jul 26, 2011
Please see this blog article, as it describes the use of a USB plug-in card reader as a much easier, faster, and less error prone way to download your photos. Note that card readers are also VERY inexpensive (some places less than $2 online with shipping).
Kodak EasyShare... • Answered on Jul 22, 2011
It could be dirty battery contacts. Take a pencil and use the eraser to burnish the contacts. It will clean them nicely. The springs are hard to do, be careful not to twist them up. If you can, use a little sandpaper glued to the end of a pen to clean them. Report back with results.
Kodak EasyShare... • Answered on Jul 01, 2011
All I can tell you from my own experience, is that the lens mechanism got damaged in some way.
Nobody's fault I'm sure, but you need to take it to a camera repair depot.
*** Before doing that, please check the warranty period either from the manufacturer or the retailer.
If you used a Credit Card to purchase it, some companies offer an extended warranty.
It will be worth your while to find out before making any decisions.
Kodak EasyShare... • Answered on Jun 27, 2011
Having received no response in six months, I assume my suggestion to use a card reader solved the problem.
Kodak EasyShare... • Answered on Mar 29, 2011
try taking the memory card out of the camera and putting it into the memory card reader, this should make the computer recognize it as a removable drive, and let you copy the files off of it.
Kodak EasyShare... • Answered on Mar 28, 2011
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Regards
Andrea
Kodak EasyShare... • Answered on Feb 09, 2011
If your batteries are good with good charge on them , then the fault is definitely with the camera system. It can be a possible failure of the electronics withing. Remove battery for few hours and try again.
if you are technically inclined , you can open the camera to check for failure of any line from the battery or a regulator. If not the main board is faulty. Seek help for estimate
Kodak EasyShare... • Answered on Feb 04, 2011
did you try changing the settings on the dial on the top right of the camera? the dial is for different settings for different types of pictures, you would need to set the camera for daytime pics, sounds like it is set up for nighttime.
Kodak EasyShare... • Answered on Jan 26, 2011
Hello
Regards
Andrea
Kodak EasyShare... • Answered on Jan 25, 2011
I had a friend that ran into the same problem, but his solution is not what I would recommend but it did work for him. He used sewing machine oil and applied a tiny amount less than a drop to the crevice of the camera body and the outer lens housing, his was stuck in the retracted position, and he got it going again without a problem.
Kodak EasyShare... • Answered on Jan 17, 2011
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Kodak EasyShare... • Answered on Jan 13, 2011
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Kodak EasyShare... • Answered on Jan 09, 2011
Kodak EasyShare C513 Digital Camera Logo
76 questions posted
Top Kodak Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
ive lost disk driver mention fact as
  • Cameras
